I'm not using a wall adapter, I'm using a battery (7AH sealed lead acid).
Code:#include <system.h> #pragma DATA _CONFIG, _CP_OFF & _LVP_OFF & _BODEN_OFF & _PWRTE_OFF & _WDT_OFF & _XT_OSC void test(unsigned char data) //stolen from a website, I can't remember where now { unsigned char bits; for (bits=0x80; bits != 0; bits >>= 1) { if ((bits & data) == bits) { set_bit(portb,0); } else { clear_bit(portb, 0); } set_bit(portb, 1); clear_bit(portb, 1); } set_bit(portb, 2); clear_bit(portb, 2); } void main() { trisb = 0; portb = 0; unsigned char f = 0; while(1) { toggle_bit(f, 5); test(f); delay_s(1); } }![]()
I fixed tho..
