+ Reply to Thread
Results 1 to 12 of 12
Thread: DS1307 Clock Freeze in Battry Supply
  1. #1
    arvinfx Newbie
    Join Date
    Nov 2008
    Posts
    47
    Default DS1307 Clock Freeze in Battry Supply
    Hi, I use a DS1307 and it's work perfect then supply power is in Vcc.
    But when i disconnect Vcc in 02:40 and one hour late I connect the Vcc unfortunately time is 02:40 ....!
    any one have this proglem whit this IC?
  2. #2
    ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,797
    Blog Entries
    13
    Quote Originally Posted by arvinfx View Post
    What back up battery are you using with the DS1307.???
  3. #3
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,694
    Blog Entries
    5
    The DS1307 is a very reliable RTCC the biggest problem I've had was forgetting to set the run bit.
    Bill
    Smart Kits build Smart People
  4. #4
    CCD
    CCD is offline
    CCD Newbie
    Join Date
    Jul 2008
    Location
    Chennai, India
    Posts
    67
    I had faced the same problem and found that the battery was weak, changed the battery and it was OK.
    check the battery voltage and also check the battery connections!
  5. #5
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,694
    Blog Entries
    5
    I like the DS1388 as it has a trickle charger for supercaps.
    Bill
  6. #6
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,797
    Blog Entries
    13
    Quote Originally Posted by blueroomelectronics View Post
    hi Bill,
    I would bet he hasn't got a backup battery connected.
  7. #7
    arvinfx Newbie
    Join Date
    Nov 2008
    Posts
    47
    HI
    I use the lithium type of battery (Maxell CR2032 3V) 3.2v in voltmer .
    And i Change it to 2.5 volt battery and my problem not solved.
    The clock and Run BIT set whit this line :
    I2CWRITE SDA,SCL,$D0,$00,[$00,$55,$18,$01,$2,$12,$08,$00]
    It is correct?
  8. #8
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,797
    Blog Entries
    13
    HI
    It is correct?
    I use a 3V lithium battery, works OK.
    Look at these images.
    It sounds like the DS1307 is being stopped at power down for some reason.
    Can you post your code.?
    Use the '#' menu symbol when you post code.
  9. #9
    arvinfx Newbie
    Join Date
    Nov 2008
    Posts
    47
    Quote Originally Posted by ericgibbs View Post
    Hi
    I test my Buttery Current in short-Circuit and it was 25ma.
    yes i can post my code read and write on my IC correctly . I use the MicroCode Studio Plus .
    I change to # but compiler give an error for this symbol !!!
    My project is temperature and i save the yesterday temperature at any o`clock on the DS1307 and show it on today ... I can read and write very easy and correctly on any where of the ram of my ds1307.!
    I see the pictures and thanks to your attendance
  10. #10
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,797
    Blog Entries
    13
    Hi
    I dont mean use the '#' for compiling.????
    When you post your program source code text to the forum, use the '#' symbol.
    example:
    post your program to the forum.
    SELECT [highlight] all the code you have posted
    and then click the '#' symbol on the upper menu bar of this message box.
    This will keep the formatting for you code correct... without the '#' your code will be displayed as a text list, without any formatting.. OK.?
  11. #11
    arvinfx Newbie
    Join Date
    Nov 2008
    Posts
    47
    example:
    Aw! sorry
    @ DEVICE    HS_OSC
    '@ device wdt_off
    INCLUDE "modedefs.bas"
    define OSC 20
    DEFINE LCD_BITS 4 'LCD bus size 4 or 8
    DEFINE LCD_DREG PORTA 'LCD data port
    DEFINE LCD_DBIT 0 'LCD data starting bit 0 or 4
    DEFINE LCD_RSREG PORTD 'LCD register select port
    DEFINE LCD_RSBIT 0 'LCD register select bit
    DEFINE LCD_EREG PORTD 'LCD enable port
    DEFINE LCD_EBIT 1 'LCD enable bit
    DEFINE LCD_LINES 4 'Number lines on LCD
    define lcd_commandus 2000
    define lcd_dataus 1000
    ' DEFINE I2C_SLOW 1
    symbol sda = portd.2
    symbol scl = portc.3
    h var byte
    m var byte
    s var byte
    ' Read time Secs,Mins,Hours,Day,Date,Month,Year,Control
    I2CWRITE SDA,SCL,$D0,$00,[$00,$22,$01,$27,$6,$11,$08,$00] ' Write to DS1307
    pause 10
    read_1307:
    I2CREAD SDA,SCL,$D0,$00,[s,m,h]
    lcdout $fe,1,"Time=",hex2 h ,":",hex2 m  ,":",hex2 s
    pause 1200
    goto read_1307
  12. #12
    arvinfx Newbie
    Join Date
    Nov 2008
    Posts
    47
    Thanks to all my problem is resolved
    dear ericgibbs u and CCD
    I scope the crystal and i see when i dis connect the Vcc the sin wave of crystal goto dead line in 2-3 sec ! i check the battery and find in my circuit capacitor connected between gnd and battry ! i remove it and anything is now okay !
+ Reply to Thread
  1. ds1307 real time clock ic
    By baftab in forum Datasheet/Parts Requests
    Latest: 9th July 2007, 03:35 AM
  2. Using the DS1307 as a 32KHz 16F877 Clock
    By William At MyBlueRoom in forum Electronic Projects Design/Ideas/Reviews
    Latest: 24th October 2006, 02:20 AM
  3. real time clock ds1307 interfacing with 8051
    By siprax345 in forum 8051/8951
    Latest: 12th May 2006, 05:41 AM
  4. How to freeze the trace?
    By atferrari in forum General Electronics Chat
    Latest: 6th August 2005, 08:18 AM
  5. battry
    By ua741 in forum Datasheet/Parts Requests
    Latest: 15th February 2005, 12:27 AM
Tags for this Thread
