Hello everybody, I was trying to write a UART program to send out few bytes of data by using PIC16F877A, CCS C compiler, MPLAB IDE, MPLAB SIM. The problem of my program is the code fail to transmit out the data to pin RC6 of Port C. So far i am just use MPLAB SIM to simulate my program and using Watch window to monitor all the register and symbol. To simulate the program i was pressing the "step into" button, and the first 2 bytes of data was load to TXREG and TSR but after that not able to load the third bytes of data beacuse TXIF flag is not set, this showing that TXREG was still full and the data look like "jam" already. from the Watch window the Port C does not show any value(0x00), i also try to press "animate" and let the program run for few minutes but still no data was show on Port C. Anybody can help to solve the problem or give some suggestion? Below is my program, #include <16F877A.h> //***** Function prototype ******// void init(void); void transmit (void); void transmit_empty (void); //*****variable declaration******// unsigned char TXSTA,RCSTA,SPBRG,INTCON,PIR1,PIE1,TXREG,PORTC,TRI SC; int count; //****** define sfr address *****// #byte TXSTA = 0x98 #byte RCSTA = 0x18 #byte SPBRG = 0x99 #byte PIE1 = 0x8c #byte INTCON = 0x8b #byte TXREG = 0x19 #byte RCREG = 0x1A #byte PIR1 = 0x0c #byte PORTC = 0x07 #byte TRISC = 0x87 char ucIPOD_packet_origin[2][7]={ {0xff,0x55,0x03,0x02,0x00,0x01,0xfa}, /* " play/pause " */ {0xff,0x55,0x03,0x02,0x00,0x08,0xf3} /* " fwd " */ }; /************************************************** ****************** FUNCTION : main() DESCRIPTION : main loop INPUT : Null OUTPUT : Null CREATE : DATE : 07/10/08 ************************************************** ******************/ void main() { init (); transmit (); while (1) { } } /************************************************** ****************** FUNCTION : init() DESCRIPTION : sfr initialization INPUT : Null OUTPUT : Null CREATE : DATE : 07/10/08 ************************************************** ******************/ void init () { PORTC = 0x00; //0b 0000 0000 //Clear Port C TRISC = 0xFF; //0b 1111 1111 //Enable USART Transmitter TXSTA = 0x24; //0b 0010 0100 //Transmit Enable //SYNC = 0, Asynchronous Mode RCSTA = 0x90; //0b 1001 0000 //Receive Enable //Serial Port Enable SPBRG = 0x40; //0b 0100 0000 //SPBRG = 64, Baudrate = 19.231KBAUD, High Baud Rate INTCON = 0x00; //0b 0000 0000 //Disable Global and Peripheral Interrupt PIR1 = 0x10; //0b 0001 0000 //USART transmit/Receive Interrupt Flag bit PIE1 = 0x00; //0b 0000 0000; //Individual enable bits for the peripheral interrupts. count = 0; } /************************************************** ****************** FUNCTION : transmit() DESCRIPTION : uart transmission INPUT : Null OUTPUT : Null CREATE : DATE : 07/10/08 ************************************************** ******************/ void transmit () { while (1) //Keep on looping { if (PIR1 == 0x10) //Check TXIF flag { //If TXREG is empty TXREG = ucIPOD_packet_origin[0][count]; //Load data count++; //Counter increment } } } [/code] I am really no idea why such condition happen, everything look like set properly but it is not run. Is it my simualtion methods is wrong or my code was having problem? Any suggestion is appreciate. Thanks | |
The TXIF goes high when the USART transmit buffer is full. I think that you are testing it the wrong way round. You should wait for it to go low not high before sending another byte. When you test bit 4 of the PIR, you shouldn't test the whole register. PIR consists of PSPIF ADIF RCIF TXIF SSPIF CCP1IF TMR2IF TMR1IF so that will only be 0x10 if all the other bits are 0. I don't write in C so I can't tell you how to just test bit 4. In assembly I would write:- Code: btfsc PIR, TXIF
goto [transmit next byte]
[whatever needs to be done instead of transmitting byte]
Diver, The TXIF goes high when the transmit buffer is empty. This generates an interrupt and allows you to load the next byte. It cannot be cleared in software and the only way to clear it is to write to TXREG. winson, I suspect Diver found your problem, namely how you test PIR1. The way to do this in C is compiler specific but you can try one of these, Code: if(PIR1&1<<TXIF){
if(PIR1.TXIF){
if(PIR1Bits.TXIF){
Mike. | |
My program is ok. I already successfully simulate my UART program by using Uart1 IO tab in MPLAB SIM. It is under Debugger > Settings > Uart1 IO. In Uart1 IO tab just click "Enable Uart IO" and select "Window" as output then press ok. After back to MPLAB main screen a "SIM Uart1" tab will exist in the output window. Press "run" to simulate the UART program and the transmitted data will show in output window as ASCII character, just have to refer ASCII table and verify the transmitted data. Thanks everybody! | |
Hi everybody. I already try my UART transmiting program on the real hardware with a breadboard but the result is not successful. I was using an oscilloscope to trace the signal that send out from the USART Tx pin of 16F877A but the scope does not show any pulses and just maintain at 0V. This program is run well in MPLAB Simulation. The peripheral circuitry of the 877A is simple, i was put the 20MHz crystal's leg to OSC1 and OSC2 with a 22pF capacitor from each crystal leg to ground. I connect 5V(3A) supply to the two VDD pin of 877A and 0V to the two VSS pin finally i also connect 5V supply to the MCLR pin for the reset purpose and i also try to put a 20k resistor to the VDD to limit the current but the result is still the same. This is all the thing that i do, but the scope does not show any digital pulses. Anybody can give me some suggestion or alert me some of the error that i done? My latest version of code is show below, Thanks... Code: #include <16F877A.h>
void init(void);
unsigned char TXSTA,RCSTA,SPBRG,INTCON,PIR1,PIE1,TXREG,PORTC,TRISC;
int count, next;
#byte TXSTA = 0x98
#byte RCSTA = 0x18
#byte SPBRG = 0x99
#byte PIE1 = 0x8c
#byte INTCON = 0x8b
#byte TXREG = 0x19
#byte RCREG = 0x1A
#byte PIR1 = 0x0c
#byte PORTC = 0x07
#byte TRISC = 0x87
#bit TXIF = PIR1.4
#bit TRMT = TXSTA.1
char remote_command_basic[3][10]=
{0xff,0x55,0x06,0x02,0x00,0x01,0x00,0x00,0x00,0xf7}, //0 Play/Pause
{0xff,0x55,0x06,0x02,0x00,0x01,0x00,0x00,0x00,0xf7}, //1 Play/Pause
{0xff,0x55,0x06,0x02,0x00,0x00,0x00,0x00,0x00,0xf8} //2 Release
FUNCTION : main()
void main()
init ();
transmit ();
while (1)
FUNCTION : init()
void init ()
TRISC = 0xFF; //0b 1111 1111 //Enable USART Transmitter and Receiver
INTCON = 0x00; //0b 0000 0000 //Global and Peripheral Interrupt Disable
count = 0;
next = 0;
void transmit ()
if (TXIF == 1) //Check TXIF flag
TXREG = remote_command_basic[next][count];//Load data
delay_cycles( 1 ); //NOP
delay_cycles( 1 );
delay_cycles( 1 );
if (count > 8) //After 10th byte
next++; //Next packet
if (next > 2) //After 3rd packet
return; //Return to main()
if (count > 9) //After 10th byte
count = 0; //Reset counter
} //End first if loop
} //End while loop
| | #6 |
The program is working after i added some code to set the configuration words.
| | #7 |
its good to hear it works! also make sure you tie MCLR to VCC with at least a 10K resistor. Not straight to VCC.
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 17th January 2009 at 03:35 AM. Reason: Typo | |
| | #8 |
Thanks Jason! Now i aware that a program will not work in a PIC chip if we do not set the configuration words in the program code. I have added the following line of code to my program: Code: #fuses hs, nowdt, nolvp, noprotect Normal 20MHz oscilloscope will not able to see the data waveform clearly, i have use a 100MHz digital oscilloscope to trace the data waveform. Regards, Winson Last edited by winson; 17th January 2009 at 09:39 AM. Reason: Add information | |
| | #9 |
Winson may i ask what kind of remote is this? Is it custom to control another project or is it some irDA type system? Just curious.
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics | |
| | #10 |
It is not an irDA system but just is a custum remote control for my project.
| problem, transmitting, uart |
| UART problem-Where is first byte? | Elvedin | General Electronics Chat | 2 | 22nd July 2008 03:19 PM |
| 8051 Serial UART Problem | ahmedragia21 | 8051/8951 | 6 | 16th December 2007 12:27 AM |
| Problem in applying configuration data to UART | tkvenki | Micro Controllers | 0 | 22nd March 2007 11:59 AM |
| PIC 16F628A UART Coding Problem | Gayan Soyza | Micro Controllers | 11 | 1st February 2007 12:59 PM |
| Maximum transmitting distance | mstechca | Electronic Projects Design/Ideas/Reviews | 7 | 4th September 2005 02:30 PM |
