| Hi: I am still learning PICs. I have two questions: 1-Does any PIC compiler handle graphics? that is to draw line, circle..etc 2-Those PIC programmers, do they program pre-defined set of PIC chips, that is if new PIC chip is introduced to market, then I have to buy new programmer?. Thanks in advance. | |
| | (permalink) | ||
| There are several graphics LCD types commonly used with PIC, both monochrome and color. They have internal controllers, so you write a memory location and forget it, it doesn't scan out lines and provide a video signal. There's at least one hardware solution to do simple text overlay on a video signal, the PIC can write to the hardware. There have been a handful of projects which do generate a crude video signal with a PIC. They're fundamentally crude because the PIC hardly has enough memory to hold a page of video, and the speed required to flawlessly generate video is quite high. | |
| Can anyone list some good online guides for writing to these dot matrix displays? I've had some experience with character displays, so I guess I'm looking for strategies on drawing shapes, special characters, etc. If it helps any, I'm using an OPTREX DMF-5042 (see attached). Color display guides would help too. | |
| The spec sheet is where you start. Be aware of the terms: "Reflective"- these only reflect ambient light. They show up fine in any amount of daylight but of course aren't visible in the dark unless lit from the front. "Transmissive"- these are solely lit by backlights and don't reflect ambient light. Ambient light washes out the display. Most laptops are transmissive. Transmissive displays appear black when off. "Transflective"- Reflects ambient light, but can also be backlit. Color displays you'll have access to are almost all transmissive. There are reflective/transflective color screens used in PDAs, some are just making it onto the surplus market and driving them is a very sketchy proposal. | |
