Since RB6 and RB7 are used for programming, but can I still use them If the programmer isnt in the circuit? Or are they dedicated to programming even if they arent being used for programming?
I believe that you're wrong.
Insinuating that they hold the bomb.
You can use them even while the programmer is attached. I have a circuit which uses port B to control the data lines of a GLCD. I just place 1k resistors in the programming connections and it all works fine. You cannot debug with this setup.
