Hi, For one of my projects I have done serial communication between 89C52 and 89C2051 microcontrollers through the RXD, TXD pins. Can anybody pls suggest a method to make this communication wireless with minimum modifications. | |
If the two micros in the vicinity then I would simply use an IR protocol & transfer the data. If I need more distance then I use license free wireless RF modules to transfer the data. Last edited by Gayan Soyza; 14th November 2008 at 08:11 AM. | |
| Can you be little more specific please? Is there any standard RF module readily available suitable for this purpose? Any idea?
See the attached file.
Thank you.
| | #6 |
| | #7 |
Thank you very much.
| | #8 |
Try Wireless Networking Solutions from Roving Networks, Inc. and http://rovingnetworks.com/documents/blueportxp.pdf for wireless RS-232 cable replacers based on Bluetooth. Dale Last edited by DSGarcia; 15th November 2008 at 03:38 AM. | |
| | #9 |
| | #10 |
| I used ST-TX01-ASK as transmitter and ST-RX04-ASK as receiver. Get data at the DATA pin of the receiver(checked with oscilloscope). But level becomes too low when connected to the RXD pin of uC. Then tried with a load resistor. Even with 100KΩ load the level comes down from 5V to <2V. Is this normal behavior OR something wrong with the device? Do we need a buffer for connecting to the RXD pin? | |
| | #11 |
Yes.It was a problem with that particular piece. | |
| | #12 |
Can anybody please suggest a method to get 2KM range? My equipments are fixed. So directional antenna is enough .
| communication, serial, wireless |
| Wireless Communication | Mubashar | Electronic Projects Design/Ideas/Reviews | 9 | 15th October 2008 03:03 PM |
| wireless communication | vyaas | Electronic Projects Design/Ideas/Reviews | 2 | 29th May 2008 09:02 AM |
| Wireless Communication | Electrostatic | General Electronics Chat | 1 | 27th June 2006 05:18 AM |
| WIRELESS & SERIAL COMMUNICATION | DTMF | Micro Controllers | 11 | 22nd July 2005 11:18 PM |
| Wireless Communication | 2camjohn | Micro Controllers | 4 | 30th August 2004 07:04 PM |
