Old 13th November 2008, 07:46 PM   #1
Default incrementing up to ... then reset
Hi
I cant seem to work out how to increment a registry value from 0 to 24 and then have this registry reset to 0 and to display this on a lcd screen.
What im trying to do is to enter a time into a pic to be compared for an alarm, the problem I have is as I press the button to increment the time the display goes from 0 - 9 then through the whole ascii code.
Any help would be appreciated
john
johnl69 is offline
Old 13th November 2008, 07:50 PM   #2
What language are you programming it in and wich pic?
But you have to convert your HEX code to a BCD code, there are examples galore of that around here I bet.
There are no stupid questions, but PLEASE, think twice before asking them
Henry T is offline
Old 13th November 2008, 08:00 PM   #3
Sorry I forgot to put I right in assembly and pic 16f877
I can do the bcd to hex conversion but my problem is getting the value to stop at 24 and then reset to 0 at the next button press
johnl69 is offline
Old 13th November 2008, 08:10 PM   #4
Euhm, long time since I worked in asm for pics, but do they have a compare function?
Or else you could decrement a register every time you increment and when that hits 0 you can do whatever... BTFSZ i believe that was?
Henry T is offline
Old 13th November 2008, 09:51 PM   #5
To reset the count back to zero if "reg" increments higher than 24:
    incf    reg,F               ;Inc the reg
    movlw    D'25'            ;load with 25 to check against reg
    xorwf    reg,W            ;Xor but dont affect the reg yet
    btfsc    STATUS,Z       ;Skip if not 25
    clrf    reg                   ;Reached 25 so set reg back to 0
    movf    reg,W            ;Get the new value of reg into w to send to your display
picasm is offline
Old 13th November 2008, 10:05 PM   #6
btfsC it was appearantly
xor'ing it will work too I guess, and then when they are equal, the Z flag gets cleared or something? Pff i need to get back into my PicASM, it's all 8051 at our school now, and there are WAYY too many instructions, wich is nice too mind you, but a risc is a little different eh :d
Henry T is offline
Old 13th November 2008, 11:20 PM   #7
Shouldn't you be counting from 0 to 23 or 1 to 24. Counting from 0 to 24 will result in a 25 hour day!!
Pommie is offline
Old 14th November 2008, 08:25 PM   #8
Thanks alot guys for your help,
Pommie, Yes it should be 0 - 23 and then 0 - 59 but it was late and I was still feeling the effects from the anastetic
johnl69 is offline
incrementing, reset
Reset chandu13 Micro Controllers 7 9th March 2007 11:14 PM
Why my MCU get reset ? manish12 Micro Controllers 6 24th October 2006 06:59 PM
incrementing and decrementing less than "1" lompa Micro Controllers 6 15th January 2005 12:26 AM
on/off set/reset please help svtiss General Electronics Chat 11 2nd November 2004 01:56 PM
Power-On Reset & Brown-Out Reset hantto Micro Controllers 5 31st August 2004 12:14 PM
