Old 11th November 2008, 11:11 PM   #31
Yeah BeeBop... but it would be nice to have that little thing like a label part. Now with a N-Channel...
AtomSoft is offline
Old 11th November 2008, 11:37 PM   #32
Originally Posted by BeeBop
Futz, nice board. Why don't you get rid of more of the square corners, though?
Originally Posted by kchriste View Post
I think it is still a Work In Progress. I can see 7 via's right off the bat that could be eliminated (From the center header on the lower edge of the PCB). Autorouter madness!
That was just a quick autorouter-only test. The board is far from finished. As I do it I'm relearning all the stuff I used to know how to do in Eagle years ago but forgot. Still a ways to go...
futz is offline
Old 11th November 2008, 11:51 PM   #33
Originally Posted by AtomSoft View Post
I actually learned all i know from
Eagle Editor Tutorial
Here's a few more:
gaussmarkov: diy fx » Eagle 2: Libraries
ECE101 - Basic Electrical and Computer Engineering » Blog Archive » EAGLE Implicit Pins - Addlevel Explanation
Eagle Library Design
I see you are still on the TI stuff. Hows it treating you? Is it living up to your expectations?
I still say, "Nice MCUs!". You can run em off fruit! I don't care much for their IDE, but I can live with it. MPLAB sets a pretty high bar for MCU IDE's.
futz is offline
Old 12th November 2008, 12:12 AM   #34
Can anyone explain the use of a mosfet over a normal transistor?
AtomSoft is offline
Old 12th November 2008, 12:17 AM   #35
awesome links thanks and cool fruit stuff. I doubt if we had to run it off fruit it would be very usefull maybe a watch? but then you lose time in between fruit but thats cool!
AtomSoft is offline
Old 12th November 2008, 12:25 AM   #36
Found it Beebop
Under Supply 2:
V-->
V<--
COOL!
AtomSoft is offline
Old 12th November 2008, 12:37 AM   #37
Found it Beebop
Under Supply 2:
V-->
V<--
COOL!
God, I'm getting old! I didn't get what you were saying.
Difference between a MOSFET and bipolar transistor? In a 'nutshell,' the transistor is controlled by current - more current on the base turns it on harder, up to the point it saturates. The FET is controlled by voltage. There are two basic kinds - depletion mode and enhancement mode. With the depletion mode a voltage on the gate which is more negative with respect to source, chokes off the device so it doesn't conduct from drain to source. Enhancement mode FETs need a voltage on the gate to turn them on. IIRC
I've heard tons of good things about the MSP micros. How will you burn the firmware into the chip?
BeeBop is offline
Old 12th November 2008, 12:41 AM   #38
Originally Posted by futz View Post
Ha, I just watched the video. You weren't kidding.
BeeBop is offline
Old 12th November 2008, 12:48 AM   #39
Thanks Beebop... Im looking at the PICDEM FS USB User Guide at the schematic. Im wondering what they use that mosfet for. Looks like it blocks the VBUS (+) from the rest of the circuit if the user supplies power via adapter. Would that be correct?
AtomSoft is offline
Old 12th November 2008, 12:56 AM   #40
I bought one of these little Olimex JTAG programmer/debuggers. It's fully TI compatible so it works with their software. TI's JTAG uses a 2x7 header.
I also have a TI eZ430 Spy Bi-Wire unit.
They're designed to run at ultra low power levels and just blip up to high speed in short bursts when needed.
futz is offline
Old 12th November 2008, 01:04 AM   #41
Sound correct to me. With no voltage at pin 3 of the regulator, the gate is pulled down to ground by R22. When the user plugs in an adapter there is a positive potential on the gate which shuts down the fet. Quite an idea; I'll have to remember that one.
BeeBop is offline
Old 12th November 2008, 01:09 AM   #42
Sweet! I'm surprised you didn't get them over at SparkFun. Ah, it's a canuck site; going to have to have a look around that one. Thanks.
I'm going to have to watch your progress on this one!
BeeBop is offline
Old 12th November 2008, 03:50 PM   #43
My version of that PICDEM FS USB board. Less Parts. Full PORTB output for use with w/e. Fully usb powered (or ICSP powered).Should be smaller and will make it have like a small expansion port. like 6-10pin for various addons. For testing. Mainly for me but since im posting the schematic feel free to use it for w/e. Im making this mainly to be a cheaper solution to the original microchip PICDEM FS USB.
Original $60
Mines would cost maybe $20 (max) to make Once you figure in the PCB Creation. The most expensive part would be the PCB & the PIC itself
AtomSoft is offline
Old 12th November 2008, 08:01 PM   #44
Just a suggestion, but if your including the programming header, AND allowing full access to port B, I think you should include the protection circuit (from the datasheets) that prevent the external circuit from interfereing with the programming and vice versa.
It wouldnt matter on a normal circuit, but on a board designed to be 'played' with - I would highly recommend this.
There will come a day when PICs will rule the world!
SMUGangsta is offline
Old 12th November 2008, 08:40 PM   #45
I shift over from datasheet pdfs to tips & tricks pdfs to manual and am always changing add/removing items. Thank you for the tip... ill be sure to add that in.
AtomSoft is offline
5x7, issue, matrix
SPI issue - HW or SW Kryten Micro Controllers 2 24th May 2008 09:30 AM
AV Issue Baggins Electronic Projects Design/Ideas/Reviews 3 6th June 2007 02:26 PM
Pic microcontrolller pwm issue ym2k Micro Controllers 2 23rd September 2004 01:44 AM
some pcb making issue...... bogdanfirst General Electronics Chat 5 5th October 2003 11:05 AM
DVD PSU Issue Callidus General Electronics Chat 1 19th September 2003 03:28 PM
