Old 11th November 2008, 03:22 AM   #16
Originally Posted by AtomSoft View Post
Here it is. I also made a Molex Mini-B and a V-Ref (7805)
Thanks. Here's my MAX3232CSE (didn't like the one that came with Eagle) and the 3M MicroSD socket.
futz.zip
futz is offline
Old 11th November 2008, 04:48 AM   #17
nice thanks. Im always adding new parts now to my eagle library. Mainly becuase im tired of looking
Ill add my own resistors with 3-10mm spacings. Caps, Crystals.. etc... And name them generically like the 5x7 Matrix is called 57_Anode_Row. This way i know what it is easy. I mostly do DIP but some SSOP, SOIC are obligations.
AtomSoft is offline
Old 11th November 2008, 06:15 PM   #18
Ha, thanks to both of you - I've collected your parts. As if I didn't have enough libs in my installation already.
Just wonder if you knew about this:
Eagle Links - Open Circuits
BeeBop is offline
Old 11th November 2008, 08:04 PM   #19
My SD socket doesn't yet have the four mounting pads/shell automatically connected to ground yet. I'm still learning about how to do that. I'll repost when it's done. If you use it before I repost, fix that.
I do now!
futz is offline
Old 11th November 2008, 08:19 PM   #20
Which SD socket did you buy, I've got to use one in an upcoming project and am baffled by the sheer amount of different SD sockets there are.
I plan on using a MAX3392E level converter for the 5V to 3.3V level translation.
Bill
Smart Kits build Smart People
Old 11th November 2008, 08:21 PM   #21
I do now!
Oh, no worries, I learned - the hard way - to always check first.
BeeBop is offline
Old 11th November 2008, 08:24 PM   #22
Ha ha, and SD card formats!
SparkFun has a nice (and cheap) level converter which I think is worth copying:
SparkFun Electronics - Logic Level Converter
BeeBop is offline
Old 11th November 2008, 08:41 PM   #23
Digikey 3M5607CT-ND. It's a micro, so if you need a full or mid size SD socket buy something else.
Haha. Ya, everyone makes one, or several or dozens of types.
I'm putting my first one on a new TI MSP430F157 board I'm designing, so no level conversion necessary. They're all low voltage MCUs.
futz is offline
Old 11th November 2008, 09:01 PM   #24
How to make a custom library part in Eagle CAD tool
is NICE! Ill make PDF and save!
I actually learned all i know from
Eagle Editor Tutorial
FUTZ:
Nice work as usual. I see you are still on the TI stuff. Hows it treating you? Is it living up to your expectations?
AtomSoft is offline
Old 11th November 2008, 09:15 PM   #25
Futz, nice board. Why don't you get rid of more of the square corners, though?
FUTZ:
That seems like a big job, but I know why you might do this; too many good things on the net disappear, and I like to have the info local. Perhaps if you do get a PDF together you will put it up here.
Thanks AtomSoft, that Eagle Editor Tutorial looks pretty good. Wish I'd had that way back when. I'm still going to enjoy reading through as there may be something left to learn.
BeeBop is offline
Old 11th November 2008, 09:58 PM   #26
I think it is still a Work In Progress. I can see 7 via's right off the bat that could be eliminated (From the center header on the lower edge of the PCB). Autorouter madness!
Nice eagle links. Thanks!
kchriste is online now
Old 11th November 2008, 10:28 PM   #27
Yes, I think you are right about that. I used to let the autorouter suggest, but these days I just avoid it.
IIRC those links came from SparkFun...
BeeBop is offline
Old 11th November 2008, 10:28 PM   #28
on the topic of eagle... When making a schematic how the hell do you make it like wireless on the schem?
Ok i know that was confusing. ill try to explain. Look at almost any schematic they have a tag on the pins like VDD might have a line to a <5v> type tag and then that tag it also on anything that needs the <5v> so anything that has a 5v tag is connected. You understand?
Look at bills page: http://www.blueroomelectronics.com/
see the junebug underneath it is a schematic. See the PGC and PGD and stuff under the right wheel in the picture. How do i make those in eagle?
AtomSoft is offline
Old 11th November 2008, 10:32 PM   #29
Um, do you mean naming the nets the same as other nets, and they get connected automatically? Like a bus?
BeeBop is offline
Old 11th November 2008, 11:11 PM   #30
Just made a "SuperSOT-3" Package for a P-Channel MOSFET...NDS352AP...
AtomSoft is offline
5x7, issue, matrix
SPI issue - HW or SW Kryten Micro Controllers 2 24th May 2008 09:30 AM
AV Issue Baggins Electronic Projects Design/Ideas/Reviews 3 6th June 2007 02:26 PM
Pic microcontrolller pwm issue ym2k Micro Controllers 2 23rd September 2004 01:44 AM
some pcb making issue...... bogdanfirst General Electronics Chat 5 5th October 2003 11:05 AM
DVD PSU Issue Callidus General Electronics Chat 1 19th September 2003 03:28 PM
