+ Reply to Thread
Results 1 to 14 of 14
Thread: Microcontroller based READER ,, ...........PROJECT HELP...??
  1. #1
    shubhamjain_007 Bad
    Join Date
    Apr 2008
    Posts
    21
    Default Microcontroller based READER ,, ...........PROJECT HELP...??
    Hello all
    I am making a project which is based on shopping malls.
    its very simple one to understand , the basic idea of project is that :-
    i want to build a microcontroller based Reader which have numeical keypad and a LED (or LCD) on it and it would be given to customer when he enters mall , then which ever products he wants he will pick it and enter its item code in the reader ( item code is printed on item) , and then press enter in reader and then enter the item quantity , , he will repeat the process for the number of products he wants and then will go to Counter , and give his reader to the receptionist and then receptionist will connect his reader to the computer (may be through Hyper terminal software) and then take the print of that and give to customer.
    so the requirement in this project is the Microcontroller based READER which has numerical keypad along with a Enter key and a display screen ,, which is capable of recieving inputs and store it and a RS232 port so it can be connetced to PC
    Can anyone help how can i make this reader ??,, what would be the components required ?? and what would be approximate cost.....
    Pls help Its urgent..............
  2. #2
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,708
    Blog Entries
    5
    You want a barcode scanner, one built into a PDA would do the trick. Symbol makes such a device.
    Bill
    Smart Kits build Smart People
  3. #3
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,708
    Blog Entries
    5
    I remember now. You were the fellow trying to build that crappi EFY burglar alarm and got mad at us when it didn't work even after everyone told you not to build it. That project was far simpler than the project you've described today assuming you plan on trying to build your own barcode or RFID reader. Unless you suddenly got some mad skills between them and now.
    Bill
  4. #4
    shubhamjain_007 Bad
    Join Date
    Apr 2008
    Posts
    21
    very sharp memory ,, well i got few skills ,, definately now i know a lot about electronics and micro controllers but i think i should change my username or else you are not going to help
  5. #5
    binzer Okay
    Join Date
    Apr 2008
    Location
    Oxford, Ct USA
    Posts
    144
    Blog Entries
    2
    Quote Originally Posted by shubhamjain_007 View Post
    I am not sure that changing your username will help you in the least. First off your project will be a dead giveaway, and quite a few people here will be able to pick you out. Instead of begging for help from the start try using Google to search for some info first as you obviously have a computer connected to the internet. I believe some stores already have these units or similar.
    Good Luck.
  6. #6
    gramo Excellent gramo Excellent gramo Excellent gramo Excellent gramo Excellent gramo Excellent
    Join Date
    Oct 2006
    Location
    Australia
    Posts
    1,207
    Blog Entries
    3
    Fail
  7. #7
    shubhamjain_007 Bad
    Join Date
    Apr 2008
    Posts
    21
    Thumbs down
  8. #8
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,708
    Blog Entries
    5
    What are you hoping we can do for you? You can try to build a UPC barcode scanner and rig it upto a microcontroller & display. What were you thinking of doing? You didn't listen then will you listen now?
    Bill
  9. #9
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,708
    Blog Entries
    5
    PS do you want to use barcodes or do you have something else in mind? When's it due.
    PPS my memory is ok but I will often search prior posts to try to get a grasp of the posters skill level.
    Bill
  10. #10
    shubhamjain_007 Bad
    Join Date
    Apr 2008
    Posts
    21
    i don't want to do it using barcode , i just want a card raeder that can take a card and has a keypad so that customer can input the code of products and take the card to receptionist for billing thats all ,, there is no roll of barcode in that
    then receptionist would insert the card in his reader(same as that of customer) connect that to computer using RS232 interface ( or RFID) and print the bill
  11. #11
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,708
    Blog Entries
    5
    For starters you'll need a magcard reader. Can you buy them where you live?
    Bill
  12. #12
    geko Good geko Good geko Good geko Good
    Join Date
    Mar 2006
    Location
    Rutland, England, UK
    Posts
    262
    Hope you don't have long product code numbers or expect the customer to enter lots of them, otherwise once they get to reception you'll have to correct all the mis-entered code numbers
  13. #13
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,708
    Blog Entries
    5
    And most products already have the UPC barcode.
    Bill
  14. #14
    kristt2001 Newbie
    Join Date
    Oct 2009
    Posts
    28
    I am doing a project concerning this using barcodes however.
    Can you give me some direction as to how to proceed with this?
+ Reply to Thread
  1. Want suggestions & info regarding This ELectronic project (Microcontroller based ) ?
    By shubhamjain_007 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 8th November 2008, 07:28 AM
  2. ''robot based on microcontroller''
    By mohammed elzaq in forum Robotics Chat
    Latest: 16th October 2008, 06:00 AM
  3. Microcontroller based UPS
    By grandestlama in forum Micro Controllers
    Latest: 23rd August 2004, 04:00 PM
  4. A Microcontroller based Analogue Waveforms Analyzer Project
    By km in forum Electronic Projects Design/Ideas/Reviews
    Latest: 30th June 2004, 06:40 PM
  5. A Simple Diode-Based RF Identification Reader
    By imgemini in forum Electronic Projects Design/Ideas/Reviews
    Latest: 22nd September 2003, 05:28 PM
Tags for this Thread
