Hello,
A few days ago I programmed the PIC16F877 chip to light a Seven Segment Display. I wrote the code in Assembly Language. The Lab I did invloved me typing up the assembly code on my computer and connecting an ICD to the PIC16F877. The PIC16F877 was then connected to the Seven Segment Display. The code worked. I used MPLAB to do the assembly code. However I am doing a new experiment where I am using the my computer (an INTEL Processor) to act as the PIC16F877. My computer is to conenct to the Seven Segment Display LCD and control it. It is conencted through the parallel Port. I am using Turbo C. How do I approach this? I know some C. Could someone advise me on where to start. Where can I get a good beginners tutorial on INTEL ASSEMBLY and Using TURBO C to start. Thanks
Yours Respectfully Avin Sinanan |
What you actually need is the code to make the parallel port drive the 7 seg display........there are plenty of resources on the net that explain how to write soft for the parallel port........
but why do you need a PIC to drive it. there are ic's that do that.
or you need to store something and then show it on the display without the somputer? |
I have to use the Intel computer processor becasue my lectuerer says i have too.
PLease help me out.
IMHO, I dont think your lecturer expects you to literally connect up a 7 seg display to you prize pc that is based on an Intel processor........
Like I said before, perhaps you are going to use the pc, with a suitable program that drives the display as you did with a pic.......but to do this you need some physical means of connecting the display to your pc, this is done via the parallel port........you ned to write a program in what ever language, turbo C in your case, that will enable your pc to drive the display........have a look here: http://www.lvr.com/parport.htm |
Hi thanks for all the help so far.
Does anyone know where I can find some sample code to do the following - Connect the PC to the 7 segment display through the Parallel Port. So that it can display a number? eg Display 5. Thanks
well you can use a simple buffer ic like 74240 or 245 or another type because the paralel port cannot hold the current needed for the display.
as for the software you think what bits you need to be H for the specific number. take the bits and convert to decimal and send that number to the port. done. some spftware can support sending the binary number directly. |
Bogdanfirst,
Ok by software do you mean the CCS complier in MPLAB. That is the software I have. DO you mean that by software? If so, it still means I have to configure the Parallel Port. I can'y just sent the binary or decimal numbers over the Parallel prt through the buffer to the 7 segment LED just so. Can I? So which means the code to configure the parallel port has to written in C since it is a CCS complier. Where can I get the code to just copy and paste? Any sites you know by chnace? SOrry for the trouble but my dead line is appraching and I have no prior expierice in this field. Thanks
CCS and MPLAB create code that only runs on a PIC. If you want to write a program for a PC using the C language, you need to obtain a compiler for the x86 processor. Gcc and Borland C/C++ are two examples.
The software bogdanfirst refers to is the program you will write to send data to the parallel port to drive your display.
If this is not what you expected, please alter your expectations. |
helo. i need a PIC16f877 language to control 2 unit of printer motors placed in x and Y axes. this is an application of cutter machine. i already have the hardware but not the software. anybody please help me... i'm using vb as my GUi with serial connection to my PIC circuit.
Start a new thread. Is not correct to ride an existing one!
Agustín Tomás In theory, there is no difference between theory and practice. In practice, however, there is. |
