Tools | Display Modes |
#2 (permalink) | |
Anyway, what you're looking for is a C compiler. I recommend SourceBoost BoostC. The demo is only code size/RAM limited - works for all supported PICs. And when you hit the limits of the demo, a full license for the compiler is only about $75! Compare with C18's price of ~$500 and PICC's price of ~$1000. It's a no brainer! Better yet, BoostC comes with both 16F (supports some 12F also) and 18F compilers.
========================= Futz's Microcontrollers & Robotics ========================= |
#3 (permalink) | |
can u explain to me more about this "SourceBoost BoostC."... does it writes C codes straight to PIC? By da way, i've done with writing on C.... i just don't know how to "burn-to-project" part.... kinda sucks at these thing.. |
#4 (permalink) | |
Really! I think you're the first to actually admit it here though.
Anyway, to program a chip you install the compiler, being sure that it gets integrated into MPLAB properly. Then start MPLAB and run the Project Wizard. Make a new project for your chip and select the compiler you just installed as the toolsuite. Add the necessary files to the project to suit your compiler (BoostC wants the appropriate lib file added) and also add the source file (put both the source and any associated header files in the project dir first). Select your programmer (assuming it's MPLAB compatible) and compile. Then program the chip. If your programmer is not MPLAB compatible you may have to run a different program to program the chip. The hex file will be in the project directory you created before compiling.
#5 (permalink) |
Hey guys..
when i tried compile this program using Sourceboost, it will show this error.. ""C:\Program Files\SourceBoost\boostc.pic16.exe" -t PIC16F876A test.c BoostC Optimizing C Compiler Version 6.89 (for PIC16 architecture) SourceBoost Technologies - Home of BoostC Free PIC C Compiler and BoostBasic Free Pic Basic Compiler Copyright(C) 2004-2008 Pavel Baranov Copyright(C) 2004-2008 David Hobday Single user Lite License (Unregistered) for 0 node(s) Limitations: PIC12,PIC16 max code size:2048 words, max RAM banks:2, Non commercial use only test.c C:\Documents and Settings\FysL\Desktop\Source Code\test\test.c(10): Unable to open include file: pic.h 1 errors detected failure Error: preprocessing error Failed to locate output file 'test.obj' Done Failed" can u help me please.. |
#7 (permalink) |
it means it can't find the file pic.h. If you look at the top of your c or h files there will be a line that states #include <pic.h>. The pic.h file is included with the compiler, though different compilers will call it by a slightly different name. Your source code is apparantly not written for sourceboost. You could either rewrite it or change compilers. Given the questions you're asking, I think you should figure out what compiler this code was written for, most likely microchip's c18 compiler. Download it from microchip.com
A rectangular bear is just a polar bear after a coordinate transform. -- I dunno who. A recent study shows that research causes cancer in rats. -- I dunno who said that one either. |
#8 (permalink) |
Or you could do it the old fashioned way: compile by hand ( convert C to assembly ), assemble by hand ( look up all the hex codes in an instruction code table ), and then enter them all into a .hex text file.
Of course when I learned it I had to enter them manually into a hex keypad. |
#9 (permalink) | |
i dont know how to make it by hand....
but i'm using pic16.. Last edited by pysch; 5th November 2008 at 11:39 PM. |
#11 (permalink) | |
Measurement changes behavior |
#12 (permalink) |
can someone convert these code to asm and hex...
i dont think i'm capable to do this anymore... i've trying for a month and using many compilers... and i have to send this thing on 8/11.. please help me on these one... if someone want to help me... i will post the code here.. thank you.. |
#13 (permalink) | |
To change that for BoostC you would use system.h. All this stuff is in the manual. Here's the first lines of a typical BoostC program for an 18F448. The CLOCK_FREQ will have to be adjusted to suit your setup. The configs will be different for 16F's. A 16F will usually have only one line. Code:
#include <system.h>
#pragma CLOCK_FREQ 20000000
#pragma DATA _CONFIG1H, _HS_OSC_1H
#pragma DATA _CONFIG2H, _WDT_OFF_2H
#pragma DATA _CONFIG4L, _LVP_OFF_4L
void main(void)
int i;
trisc=0;
while(1){
for(i=0;i<256;i++){
latc.3=1;
delay_10us(i);
latc.3=0;
delay_ms(5);
delay_ms(50);
========================= Futz's Microcontrollers & Robotics ========================= Last edited by futz; 6th November 2008 at 12:58 AM. |
#14 (permalink) | |
make a new file.. and name it as system.h? |
#15 (permalink) | |
Replace the pic.h header line in your program with the system.h one. Then you'll have to make some other changes to suit differences in how the two compilers name things like registers, and how they access bits in registers.
========================= Futz's Microcontrollers & Robotics ========================= Last edited by futz; 6th November 2008 at 01:07 AM. |
| Help convert 12c508a file to 16F84 | OY2L | Micro Controllers | 3 | 26th March 2008 01:49 PM |
| I want to convert Voltage to digital (BCD Code) | nuttaphong191 | Electronic Projects Design/Ideas/Reviews | 7 | 15th March 2008 02:30 PM |
| Convert binary to BCD code | genetica | General Electronics Chat | 7 | 16th September 2007 02:37 PM |
| convert hex code to 7 seg display | electroicarus | General Electronics Chat | 12 | 26th July 2006 01:58 PM |
| how can i convert this code from C language into assembly ?? | zika1212 | Micro Controllers | 1 | 24th March 2004 10:56 PM |
