| Hello people, does anyone know for sure if inverted TTL means negative logic? if not, can one explain to me what inverted TTL.. Thanks!
__________________ i\'m actually a novice in the robotics field and would love to get help to lunch my projects.. | |
I would only consider it negative logic if the entire design worked that way. | ||
| if this is in response to the other post then inverted TTL is the output from a microcontroller for controlling serial devices, so when something is sent from the controller to the recieving device - the signal is the opposite of what a full RS232 serial device would show - eg a '1' on RS232 is actually -12v, and a '0' is +12v, although if you are dealing with inverted TTL in this sense a '1' is +5v and a '0' is 0v - This is the way that many serial devices work to negate the effect of having to use MAX232 ect. to provide the +12v and -12v for full RS232 spec. I hope that makes sense to you :? | |
