Starting out a new project and just trying to write some bits for my computer to read (just using cat /dev/ttyS1)- here is part of what I have so far, not sure why it doesn't work Main: call Print_Message movlw 90H movf TXREG call Delay1sec goto Main Print_Message: call LCD_Init call Delay10ms movlw MSG1 ;movwf TXREG call LCD_PrintString call LCD_NewLine movlw MSG2 call LCD_PrintString call Delay1sec call LCD_Init call Delay10ms movlw MSG3 call LCD_PrintString call LCD_NewLine ;call Voltage movlw MSG4 call LCD_PrintString call Delay1sec return | |
Do you setup the uart somewhere else in your code?. The pic's uart requires some setup code before you can start copying things to TXREG Secondly, you should check bit TXIF of register PIR1 to see you are allowed to write new data to TXREG. This flag indicates the usart is ready for transmission. | |
Ooops, guess I missed copying some code- LIST p=16F877 #include "p16f877.inc" errorlevel 1, -302 ;Suppress bank 0 messages ; Memory Declarations cblock 0x20 ; Start of general purpose memory endc ORG 0x000 Start: goto Init ; Execute code ORG 0x004 Interrupt: goto Init ; Ignore interrupts Init: BANKSEL TRISA movlw b'11111111' movwf TRISA BANKSEL TRISB movlw b'11111111' ; All inputs including user buttons movwf TRISB BANKSEL TRISC movlw b'11110000' ; LED lines as outputs movwf TRISC BANKSEL TRISD movlw b'00000000' ; LCD lines all are outputs movwf TRISD BANKSEL OPTION_REG movlw b'00000111' ; 0=PortB weak<7>,(Intedg<6>),(T0CS<5>),(T0SE<4>),(PSA<3>)25 6<210> movwf OPTION_REG ;;;; Initialize UART BANKSEL SPBRG ; Set up baud rate (9600) movlw .129 movwf SPBRG ; Set up serial port movlw 0x24 movwf TXSTA BANKSEL RCSTA ; Enable port movlw 0x90 movwf RCSTA BANKSEL PORTA ; Normal bank again | |
Can't see anything wrong with the setup code at first glance But you'll need to check TXIF before transmitting Code: Transmits W over the serial port SerialTransmit BANKSEL TXREG BTFSS PIR1, TXIF ;Buffer empty? GOTO $-1 ;no? then wait until it is MOVWF TXREG ;Transmit W RETURN | |
| rs232 |
