+ Reply to Thread
Results 1 to 3 of 3
Thread: lcd display with hd44780 display driver
  1. #1
    ANUPAMA Newbie
    Join Date
    Mar 2004
    Location
    INDIA
    Posts
    10
    Default lcd display with hd44780 display driver
    i am using 2 line lcd display module . the module uses hd44780 driver. while my programme works for first line , the second line does'nt get activated. the driver manual says to use 40h as ddram address for second line. i went by the above instruction but without sucess. to check if my programming is correct i programmed the first line to have dispaly in the first and fifth position by changing the address counter as given in the manual . it worked properly. can anyone suggest what could be the problem
  2. #2
    Exo
    Exo is offline
    Exo Newbie
    Join Date
    Sep 2003
    Location
    Belgium
    Posts
    1,884
    What font are you using? 44780's allow the use of 2 fonts, 5*7 and 5*10 pixels. If you selected 5*10 pixels then the 2nd row is unavailable.
  3. #3
    StupidDum Newbie
    Join Date
    Nov 2003
    Location
    Malaysia
    Posts
    242
    most probably you didn't initiliaze it properly
    there is a command to select display for 1 line, or 2 lines
    check the lcd datasheet properly
+ Reply to Thread
Tags for this Thread
