+ Reply to Thread
Results 1 to 6 of 6
Thread: Who's gonna explain me from a to zz about osscc options
  1. #1
    TKS
    TKS is offline
    TKS Newbie
    Join Date
    Sep 2003
    Location
    Winterswijk
    Posts
    560
    Default Who's gonna explain me from a to zz about osscc options
    pleaze i need to know where to fin the info and how to use it..11
    i'm getting mad..
    TKS
  2. #2
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,794
    Default Re: Who's gonna explain me from a to zz about osscc options
    Quote Originally Posted by TKS
    It's all in the MicroChip datasheets and application notes (as are most things!).
    But basically don't get excited over the various options, usually you only use one or two of them - XT for crystals up to 4MHz, and HS for faster crystals - but they seem pretty tolerant anyway!.
    I purposely used the 16F628 in my tutorials because it has an internal oscillator, by including the config setting in the source code it removes any worries about oscillators.
  3. #3
    TKS
    TKS is offline
    TKS Newbie
    Join Date
    Sep 2003
    Location
    Winterswijk
    Posts
    560
    Default oww boy
    wy you don't untherstand me aftermaking suchs good tutorials..??
    the data sheet is like hocus spocus for me..
    and i want to learn wy i put something in the asm file..
    soow if you can do me a favour..(i hope you do and have fait in it..)
    tell me exactly..
    : how you come choosing the config you did when you wrote : __config 0x3D18
    in the data sheets of the chip used: 16F628 i see this on page 26
    bit 7 bit 0
    bit 7-4 Unimplemented: Read as '0'
    bit 3 OSCF: INTRC/ER oscillator frequency
    1 = 4 MHz typical(1)
    0 = 37 KHz typical
    bit 2 Unimplemented: Read as '0'
    bit 1 POR: Power-on Reset STATUS bit
    1 = No Power-on Reset occurred
    0 = A Power-on Reset occurred (must be set in software after a Power-on Reset occurs)
    bit 0 BOD: Brown-out Detect STATUS bit
    1 = No Brown-out Reset occurred
    0 = A Brown-out Reset occurred (must be set in software after a Brown-out Reset occurs)
    Note 1: When in ER Oscillator mode, setting OSCF = 1 will cause the oscillator frequency to change to the frequency specified by the external resistor.
    soow tell me please how do you produce 0x3D18 from the text above.
    my calc says that: 3D18 = 11110100011000 or has this nothing to do whit it..??
    TKS
    hope i'm doing right.. and that you can explain..
    also hope that i will be able to produce config settings my self.
    if you like it more i put my nonworking code here...(masm accepted whit 0 faults..)
  4. #4
    TKS
    TKS is offline
    TKS Newbie
    Join Date
    Sep 2003
    Location
    Winterswijk
    Posts
    560
    Default i need to know because
    if i'm not for sure that is good how can i look further..??
    whit other words.. how can i go buying stuff if i don't know if i have the money..
    if i wanna know i my program is good thirst i will have to check that my settings are correct..
    and guess 1 think timing is important..my ledd doesn't flash..
    it keepr lighting..
    will post the code:
  5. #5
    csaba911 Good csaba911 Good csaba911 Good
    Join Date
    Jul 2003
    Location
    Canada
    Posts
    219
    Check page 94 :!: :!:
    0x3D18 = 11 1101 0001 1000 '14 bit config, 13 to 0.
    bit 13-10 =1111 ;Program memory code protection off
    bit 9 =0 ;Unimplemented: Read as ‘0’
    bit 8 =1 ;Data memory code protection off
    bit 7 =0 ;RB4/PGM is digital I/O
    bit 6 =0 ;BOD Reset disabled
    bit 5 =0 ;RA5/MCLR pin function is digital Input
    bit 3 =1 ;PWRT disabled
    bit 2 =0 ;WDT disabled
    bit 4,1-0=100 ;INTRC oscillator: I/O function on RA6/OSC2/CLKOUT pin
    I hope this help !!
    STEVE
  6. #6
    falleafd Newbie
    Join Date
    May 2003
    Location
    Vietnam
    Posts
    412
    Try Mid Range manual at Section 2: Oscillator and Section 27: Device Configuration Bits, you will know exactly what to do. You can download it on www.microchip.com
+ Reply to Thread
Tags for this Thread
