Old 6th March 2004, 05:28 AM   (permalink)
Default How to transfer file from PC to eeprom?
can anybody tells me how to transfer file from PC to eeprom? (via PIC)
Thanks!
janetsmith2000@yahoo.com is offline
Old 6th March 2004, 06:58 AM   (permalink)
Default Re: How to transfer file from PC to eeprom?
Thanks!
With an EEPROM programmer, there are various ones you can download and build, and various software available. Try doing a search for 'ponyprog' which is a popular one, and 'ICProg' also programmes EEPROM's.
Old 6th March 2004, 10:56 AM   (permalink)
I wonder, must I use eeprom programmer? Is there any other alternative, like using rs232?
Old 6th March 2004, 11:37 AM   (permalink)
You could use the serial port, or the parallel port, to interface to a programmer - you can't just connect directly to a chip. If you search for 'ponyprog' there are some very simple EEPROM programmer circuits you can build.
Old 6th March 2004, 05:26 PM   (permalink)
PonyProg can use the serial port or the parallel port, depending on the interface that you use. As for me, I use PonyProg with the so-called "STK200" dongle (the "dongle" is the "interface," it has a '244 and some other misc. parts on it) for the chips PonyProg supports. Problem is, for me, it doesn't support many of the ones I like to use, esp. with higher densities. That's why I built my own. It transfers binary files using a terminal program using XModem/CRC Protocol. Next week I'm going to start on a DataFlash programmer using the same scheme, unless one of ya'll knows of an existing programmer for PC->DataFlash.
j.
John Sorensen is offline
Old 8th March 2004, 11:36 PM   (permalink)
If your PIC can write to the EEPROM you can send your EEPROM data through RS232 and have the PIC write it to the EEPROM. What sort of file do you need to save? is it calibration data? Text? Hyperterminal will let you send files through RS232.
Brent
bmcculla is offline
Old 11th March 2004, 11:24 AM   (permalink)
I have uploaded the files
i use my FTP in my project to upload it
hoho, I think having TCP/IP can save me from using EEPROM programmer.
