Old 3rd March 2004, 04:54 PM   #1
Default PIC 16f84A and PowerTip Alphanumeric display
Hello people,
I'm trying to get a PIC 16f84A to output it's PORT A to a PowerTip PC1602-ARS-F-EB Alphanumeric Display.
I've got the code to do this with PORT B but would rather use PORT A with 5 wires. This will involve using the LCD in four wire mode.
Can someone please tell me how to do this?
/* connects 2 line LCD panel */
/* using Hitachi 44780 controller */
/* assigments as follows: */
/* PORTB:0 -----> LCD bit 4 */
/* PORTB:1 -----> LCD bit 5 */
/* PORTB:2 -----> LCD bit 6 */
/* PORTB:3 -----> LCD bit 7 */
/* PORTB:4 -----> LCD RS */
/* PORTB:5 -----> LCD E */
/* function prototypes */
char lcd_start ( void ) ;
char lcd_clear ( void ) ;
char lcd_print_ch ( char ch ) ;
char lcd_print ( const char * message ) ;
char lcd_cursor ( char x, char y ) ;
/* You will have to change these bits */
/* if the hardware changes */
/* You will also need to change: */
/* setup_lcd and lcd_raw_send */
/* masks for control bits */
#define RSMASK 0x10
#define EBIT 0x05
/* defined values for delays */
/* tested up to 20Mhz PIC */
/* standard write delay */
#define PUTCH_DELAY 250
/* clear and cursor home take longer */
/* special delay for them */
#define CLEAR_DELAY 5000
/* power up delay to let the LCD settle */
#define POWER_UP_DELAY 10000
/* bit delay to let the ports settle */
#define BIT_DELAY 2
void lcd_delay ( int size )
int i ;
for ( i = 0 ; i < size ; i++ ) ;
/* sends a byte out to the LCD */
/* the byte is given by in, the */
/* mask is used to allow the */
/* state of RS to be set as well */
void lcd_raw_send ( unsigned char in,
unsigned char mask )
unsigned char pb ;
/* use a PIC assembler */
/* to swap the nibbles in the */
/* input */
/* puts high nibble at the */
/* bottom of the byte */
asm swapf param00_lcd_raw_send,F
/* OR in the mask */
pb = (in & 0x0f ) | mask ;
/* OR in the other bits */
/* PORTB */
pb = pb | (PORTB & 0xc0) ;
/* send the data */
/* send the data */
/* don't disturb the other */
/* bits in PORTB */
PORTB = pb ;
/* let the bits settle */
lcd_delay ( BIT_DELAY ) ;
/* now clock the bit out */
/* by raising and lowering E */
set_bit ( PORTB, EBIT ) ;
clear_bit ( PORTB, EBIT ) ;
/* put the low nibble back */
/* into in */
/* PORTB */
/* send the data */
/* send the data */
/* bits in PORTB */
PORTB = pb ;
/* do the delay here */
lcd_delay (PUTCH_DELAY) ;
/* puts a character at the cursor */
/* position */
char lcd_print_ch ( unsigned char in )
/* use raw send with RS set */
lcd_raw_send ( in, RSMASK ) ;
return 1 ;
/* sends a command to the LCD */
void lcd_command ( unsigned char in )
lcd_raw_send ( in, 0 ) ;
/* clear the display */
/* and home the cursor */
lcd_command ( 0x01 ) ;
/* do extra delay here */
lcd_delay (CLEAR_DELAY) ;
lcd_command ( 0x02 ) ;
return 1 ;
/* position the cursor */
char lcd_cursor ( unsigned char x,
unsigned char y )
if ( y==0 )
/* position for line 0 */
y=0x80 ;
else
/* position for line 1 */
y=0xc0 ;
lcd_command ( y+x ) ;
return 1 ;
const unsigned char lcd_init [5] =
/* LCD initialise */
0x33,
/* Set for 4 bit operation */
0x32,
/* Set for 2 line LCD */
0x2c,
/* Select move after write */
0x06,
/* disp. on cursor off blink off */
0x0c
char lcd_start (void)
unsigned char i, t ;
/* Select the Register bank 1 */
set_bit ( STATUS, RP0 ) ;
/* set bits of PORTB for output */
/* change for different hardware */
/* clear bottom five bits for LCD */
/* don't change any other bits */
TRISB = (TRISB & 0xc0) ;
/* Select the Register bank 0 */
clear_bit( STATUS, RP0 );
/* give the LCD time to settle */
/* from power up */
lcd_delay ( POWER_UP_DELAY ) ;
for ( i=0 ; i < 5 ; i++ )
lcd_command ( lcd_init [i] ) ;
lcd_clear () ;
return 1 ;
/* lcd_print accepts a pointer */
/* parameter which points at the */
/* string to be printed */
char lcd_print ( const unsigned char * mess )
unsigned char i = 0 ;
/* treat the pointer as an */
/* array and send bytes until */
/* we find an element with 0 */
/* in it */
while ( mess [i] != 0 )
lcd_print_ch ( mess[i] ) ;
i++ ;
return 1 ;
const unsigned char hello [6] = { 'h','e','l','l','o',0x00 } ;
void main ( void )
unsigned char x, y ;
while (1) {
lcd_start () ;
lcd_cursor ( 5, 0 ) ;
lcd_print ( hello ) ;
lcd_cursor ( 0, 0 ) ;
lcd_print_ch ( 'x' ) ;
lcd_cursor ( 15, 0 ) ;
lcd_cursor ( 0, 1 ) ;
lcd_cursor ( 15, 1 ) ;
while (1) ;
27 is offline
Old 9th March 2004, 03:19 PM   #2
Anybody? I'm quite new to PIC programming.
27 is offline
16f84a, alphanumeric, display, pic, powertip
