Im trying to make a variable timer using 4 input pins of my 12f675 pic but Im unable to read a voltage off Pins 0,1 and 4 for some reason. Pin 5 input functions as it should but cant read a logical 1 off the others. Programs written and programmed in Basic Pro using MPLabs. Small program goes as follows, I added check for 0 on Pin0 to see if it was even configed as a input correctly. As I assumed I can get a longer delay if I check for 0 <so I am reading inputs I assume just not a logical 1>. GPIO = %00111101 W0 VAR Word W1 VAR Word W2 VAR Word W3 VAR Word W4 VAR Word B0 VAR Byte loop: W0 = 0 W1 = 0 W2 = 0 W3 = 0 Peek GPIO, B0 if B0.0 = 1 Then W0 = W0 + 3000 Endif if B0.0 = 0 Then W0 = W0 + 24000 Endif if B0.2 = 1 Then W1 = W1 + 6000 Endif if B0.4 = 1 Then W2 = W2 + 12000 Endif if B0.5 = 1 Then W3 = W3 + 24000 Endif W0 = W0 + 15000 High 1 Pause 200 Low 1 Pause W0 Pause W1 Pause W2 Pause W3 Goto loop Originally all the inputs would add to W0 and the end result was added once more to 15K to ensure atleast a 15 second delay. I added the extra words and pauses to make sure I wasnt overwritting the pause<65K limit I believe>. As for hardware Im using 4 10K resistors each in series with a SPST switch connected to ground. All inputs connected between the switch and resistor, 1 resistor and switch per input. <aka HIGH on open LOW on closed>. Any help will be greatly appreciated. | |
| | #2 | |
The 12F675 has A/D converter inputs on those pins, wich are activated on power on, you must turn of the A/D to make the pins act as digital IO Look at the datasheet to see how to do it. I think it was: -clearing bit 0 of register ADCON0 to turn off ADC -clearing bits 0-3 of register ANSEL to turn the pins into digital IO | |
2 late again :roll:
:lol: 8) | |
| | #6 |
Cool that got it ![]() I read threw that section on that data sheets already but seeing that my special registers on my Pic Pro Plus showed them all as cleared I didnt mess with it. After manually adding these commands it works like a charm. ADCON0.0 = 0 ANSEL.0 = 0 ANSEL.1 = 0 ANSEL.2 = 0 ANSEL.3 = 0 Thanks Exo and Nigel for the quick replies. | |
| input, problems |
