When would one use the 876 instead of the 877? It seems that the 877 offers a lot more io and memory for a few cents more. | |
For a smaller board.. I guest
__________________ Falleaf mail@falleaf.net English forums at PIC Vietnam - Vietnamese Electronics forums R&P Trading and Forwarding Co. Ltd. Distributor of Microchip in Vietnam | |
Other companies would... For mass production they try to save every penny they can. The few cents you say turn into big numbers when you're mass producing something. | |
| | #4 | |
It should be 'when would one use an 877 instead of an 876', the answer is when you need more I/O than an 876 provides. You don't get more memory, just more I/O, they are pretty well identical chips - but one has less legs :lol: The biggest advantage of the 876 is the 'skinny DIP' case, it makes it a lot smaller - the 877 is just huge! - if the 876 was full width, it wouldn't be half as useful. If you use an 877 where an 876 would do, you are obviously wasting some facilities on the chip - money wise, there's not any difference worth bothering about. I use both, if an 876 will do, I'll use that - if it won't, I move to an 877 - if I was starting a project, where I suspected I might need as much I/O as possible, I'd probably start with the 877 to begin with. | ||
| | #5 | |
ever seen a 877 in TQFP package. smaller then a F84 | ||
| | #6 | |
| | #7 |
Previously, i use 877 in my project. However, while i plotting the PCB layout, i realise 877 is waste of space. (of course, i am using the DIP). As there are many unused pins in my 877, i replace it with 876 and just made some slight change in my program. Why microchip produce such wide range variety of microcontroller?? cost is a factor. 877 is more expensive, and making the cost of PCB higher. so, if you dont need so much pins, why would u wan to use 877. | |
