| Hello everyone I have a problem with buttons. Im new to PIC BASIC pro. You see I have this program which supposedly will take the analog input and convert into digital in binary form one at a time. Sample RA0 and RA1. I want to take the value of RA0 first by pressing the button attach on RC3 and when I want to take the value of RA1 using the button attach on RC1, I cant get them both, the buttons seems do not work. Soon I will use three buttons to add RA3 as input, can anyone help me with this. heres my code: INCLUDE "BS1DEFS.BAS " Define OSC 4 Define ADC_CLOCK 3 'default value is 3 DEFINE ADC_BITS 8 Define ADC_SAMPLEUS 10 'default value is 20 Define LCD_BITS 8 'allowed values are 4 and 8 - the number of data interface lines Define LCD_DREG PORTB Define LCD_DBIT 0 '0 or 4 for 4-bit interface, ignored for 8-bit interface Define LCD_RSREG PORTD 'RS port Define LCD_RSBIT 1 'RS pin Define LCD_EREG PORTD 'En port Define LCD_EBIT 3 'En pin Define LCD_RWREG PORTD 'R/W port Define LCD_RWBIT 2 'R/W pin DEFInE LCD_LINES 4 'LCD lines DEFINE BUTTON_PAUSE 50 'button debounce delay is 50ms an0 var word 'set variable an0 as word an1 var word 'set variable an1 as word btn1 var PORTC.3 'set RC3 to select RA0 as analog input btn2 var PORTC.4 'set RC4 to select RA1 as analog input ledrc0 var PORTC.0 'set ledrc1 as RC0 indicates RA0 as input ledrc1 var PORTC.1 'set ledrc2 as RC1 indicates RA1 as input TRISA = %11111111 ' Set PORTA to all input ADCON1 = 4 ' Set RA0, RA1 & RA3 as analog input goto loop 'skip subroutine ra0: 'ra0 subroutine high ledrc0 = 1 low ledrc1 = 0 Adcin 0, an0 Lcdout $fe, $01 ' Clears your LCD, sets cursor to Line 1 Column 1 Lcdout $fe, $c0 ' Cursor to Line 2 Column 1 Lcdout $fe, $14 ' move cursor 1 space Lcdout $fe, $14 ' move cursor 1 space Lcdout $fe, $14 ' move cursor 1 space Lcdout $fe, $14, " ", "RA0", " ", "VALUE:" ' Formatted text for line 2 Lcdout $fe, $14 ' move cursor 1 space Lcdout $fe, $94 ' cursor to line 3 Lcdout $fe, $14, BIN8 an0 ' Formatted text for line 3 pause 1000 return ra1: 'ra1 subroutine high ledrc1 low ledrc0 ADCIN 1, an1 Lcdout $fe, $01 ' Clears your LCD, sets cursor to Line 1 Column 1 Lcdout $fe, $c0 ' Cursor to Line 2 Column 1 Lcdout $fe, $14 ' move cursor 1 space Lcdout $fe, $14 ' move cursor 1 space Lcdout $fe, $14 ' move cursor 1 space Lcdout $fe, $14, " ", "RA1", " ", "VALUE:" ' Formatted text for line 2 Lcdout $fe, $14 ' move cursor 1 space Lcdout $fe, $94 ' cursor to line 3 Lcdout $fe, $14, BIN8 an1 ' Formatted text for line 3 pause 1000 return loop: 'main if btn1 = 1 then Gosub ra0 endif if btn2 = 1 then gosub ra1 endif Goto loop 'loop forever END | |
| you have to set your TRISC as well. | |
