I did something stupid today. I bought a 12F675, and without reading the datasheet i erased it the first thing i did. Very stupid! Now the OSC calibration values are gone, aren't they? How can i get them back? The datasheet says something about that it is possible to get them form Microchip. Help!!! How shall i do? Is the value uniqe for every single PIC, or is it the same for all of them? | |
| | #2 | |
I wouldn't have thought MicroChip could tell you what it might be, they would need to be able to recognise that exact chip to do so. I've got some at home, I'll check what their calibration bytes are and let you know later (unless someone does it first?). Apart from that you will have to measure it - write a program to output a frequency on one of the pins and measure the frequency. Run the same program on a known correct chip (even a 4MHz 16F84 will do) and compare the frequencies. Adjust the calibration byte in the 12F675 until it runs at as close a frequency as possible. If you have access to an oscilloscope you could compare them side by side with one feeding the X input and the other the Y input. Although it's not much help to you, the current working version of WinPicProg (which will be the next released version) reads the calibration byte before erasing or programming - and writes it back for you :lol: I haven't been caught out (yet!), but I made sure my software made it difficult to be caught out. | ||
Ok, yeah i have an oscilloscope. It would be great if you could send me your bytes, so i have something to start from!
| | #4 | |
$347C $3478 $3478 $3470 | ||
I tested 3 of 'em 3478h for 2 of 'em 347Bh for the other one | |
| | #6 |
Okay, thanx! Now i have something to start on!
| | #7 |
How do i set the value in the code? I am using PicBasic Plus 2.13 I tried this: DEVICE 12F675 SET_OSCCAL OSCCAL = $3478 But then the compiler says: *** Value will overflow a BYTE size variable! *** How do i do it in ASM? | |
| | #8 | |
Code: ORG 0x03FF
RETLW 0x78
| calibration |
