Hi. I have a problem when I try to program with IC-Prog in a pic16f84a, when I click in the "Program All" bottom it seem like is doing the programming ok, but after the data verifycation (Verifying Data (64) bytes) i have an error thar says: "Verify failed at address 0000h!". All the conections and cables are ok, a think some configuration assues are wrong but I don't know what... I have WinXP but i don't know what. Someone please help me. | |
You could have Code Protect on... Other wise i think your MC is busted... most likely the CP fuse...
__________________ www.winpicprog.co.uk - Great PIC language tutorials. | |
| | #3 | |
If you could think is the Code Protect On... How could i change that? | ||
| | #4 | ||
But if it works OK on another PC it seems most probable that you have a fault with this PC - is it a laptop? - these often have non-standard parallel ports. Also the port could be faulty, or some other program could be accessing the port (again, I've had reports of this on laptops). | |||
how long are the cables you use? and are they shielded? I've had some programming problems with the 16f876A and i've found out is was due to my cable between pc and programmer, and the cable between programmer and pic beiing to long & not shielded. (they were both only 25cm long and already this gives problems) I've replaced the cables with shielded ones and know it all works fine. | |
| | #6 | |
| | #7 | |
| | #8 |
This sounds like the exact same problem that I am experience all the way down to the same OS and programmer I measured the voltage coming out of the programmer which needs to be 4.5-5.5 vdc and it seems to average around 4.3 vdc or less. I wonder if this is the problem? Unfortunately I do not have another computer at the house to test this theory with. Maybe I'll try one at the office during the weekend sometime. | |
| | #9 | |
| | #10 |
read this trouble shooting manual on this site about the jdm programmer http://www.ucapps.de/mbhp_jdm.html succes | |
| error, icprog |
