| i need a flow chart for a digital clock so that i can understand how it is working with the PIC microcontroller.i have found the code on the internet but i do not understand how the program is actually working.so if anyone has flow chart for the digital clock, can u share it with me? thank you | |
| would be nice if we knew what clock you're talking about ... | |
| the code of the digital clock is shown below: ' LCD clock program using On Interrupt ' Uses TMR0 and prescaler. Watchdog Timer should be ' set to off at program time and Nap and Sleep should not be used. ' Buttons may be used to set hours and minutes DEFINE LCD_DREG PORTD ' Define LCD connections DEFINE LCD_DBIT 4 DEFINE LCD_RSREG PORTE DEFINE LCD_RSBIT 0 DEFINE LCD_EREG PORTE DEFINE LCD_EBIT 1 hour VAR BYTE ' Define hour variable dhour VAR BYTE ' Define display hour variable minute VAR BYTE ' Define minute variable second VAR BYTE ' Define second variable ticks VAR BYTE ' Define pieces of seconds variable update VAR BYTE ' Define variable to indicate update of LCD i VAR BYTE ' Debounce loop variable ADCON1 = 7 ' PORTA and E digital Low PORTE.2 ' LCD R/W low = write Pause 100 ' Wait for LCD to startup hour = 0 ' Set initial time to 00:00:00 minute = 0 second = 0 ticks = 0 update = 1 ' Force first display ' Set TMR0 to interrupt every 16.384 milliseconds OPTION_REG = $55 ' Set TMR0 configuration and enable PORTB pullups INTCON = $a0 ' Enable TMR0 interrupts ON INTERRUPT GoTo tickint ' Main program loop - in this case, it only updates the LCD with the time mainloop: PORTB = 0 ' PORTB lines low to read buttons TRISB = $f0 ' Enable all buttons ' Check any button pressed to set time IF PORTB.7 = 0 Then decmin IF PORTB.6 = 0 Then incmin ' Last 2 buttons set minute IF PORTB.5 = 0 Then dechr IF PORTB.4 = 0 Then inchr ' First 2 buttons set hour ' Check for time to update screen chkup: IF update = 1 Then LCDOut $fe, 1 ' Clear screen ' Display time as hh:mm:ss dhour = hour ' Change hour 0 to 12 IF (hour // 12) = 0 Then dhour = dhour + 12 EndIF ' Check for AM or PM IF hour < 12 Then LCDOut DEC2 dhour, ":", DEC2 minute, ":", DEC2 second, " AM" Else LCDOut DEC2 (dhour - 12), ":", DEC2 minute, ":", DEC2 second, " PM" EndIF update = 0 ' Screen updated EndIF GoTo mainloop ' Do it all forever ' Increment minutes incmin: minute = minute + 1 IF minute >= 60 Then minute = 0 EndIF GoTo debounce ' Increment hours inchr: hour = hour + 1 IF hour >= 24 Then hour = 0 EndIF GoTo debounce ' Decrement minutes decmin: minute = minute - 1 IF minute >= 60 Then minute = 59 EndIF GoTo debounce ' Decrement hours dechr: hour = hour - 1 IF hour >= 24 Then hour = 23 EndIF ' Debounce and delay for 250ms debounce: For i = 1 TO 25 Pause 10 ' 10ms at a time so no interrupts are lost Next i update = 1 ' Set to update screen GoTo chkup ' Interrupt routine to handle each timer tick Disable ' Disable interrupts during interrupt handler tickint: ticks = ticks + 1 ' Count pieces of seconds IF ticks < 61 Then tiexit ' 61 ticks per second (16.384ms per tick) ' One second elasped - update time ticks = 0 second = second + 1 IF second >= 60 Then second = 0 minute = minute + 1 IF minute >= 60 Then minute = 0 hour = hour + 1 IF hour >= 24 Then hour = 0 EndIF EndIF EndIF update = 1 ' Set to update LCD tiexit: INTCON.2 = 0 ' Reset timer interrupt flag Resume End this code was found at melabs.com but since i just started to learn PIC and some of the routine still trouble me.so i hope i can get a flow chart for this clock for best understanding. thank u | |
