I'm using a 16f876
pins a0 (input) a1 a2 a3 a5 will work but a4 not i will to have that a4 is an output so i can drive a led on this pin i'm using pic basic DEFINE OSC 4 'CLOCK FREQUENTIE IS 4MHZ' TRISC = %00000000 TRISA = %00000001 Adcon1 = %00000111 adcon0 = %00000000 TIJD var word KNOPPEN var byte XRICHTING var byte YRICHTING var byte MAIN: 'GOTO MEETTIJD 'IF (TIJD>2500)OR(TIJD<3500) THEN 'PORTA.5 = 0 'pause 1000 'ELSE 'PORTA.4 = 0 PORTA.1 = 1 PORTA.2 = 1 PORTA.3 = 1 PORTA.4 = 1 PORTA.5 = 1 'pause 1000 'ENDIF GOTO MAIN MEETTIJD: pulsin PORTA.0, 1, TIJD RETURN ZENDNAARUSB: PORTA.1 = 0 PORTA.2 = 0 PORTA.3 = 0 PORTC = 0 KNOPPEN = 32 XRICHTING = 128 YRICHTING = 255 PORTC = KNOPPEN PORTA.1 = 1 PAUSE 100 PORTC = 0 PAUSE 100 PORTA.1 = 0 pauseus 1 PORTC = XRICHTING PORTA.3 = 1 pauseus 1 PORTA.3 = 0 pauseus 1 PORTC = YRICHTING PORTA.2 = 1 pauseus 1 PORTA.2 = 0 pauseus 1 RETURN END |
A4 is often an open-collector output on PIC's, it can only sink current, not source it - add a pull-up resistor to make it work more like a normal output. As you are wanting to drive an LED, you could connect the LED and series resistor from the pin to +5V, the LED would then light when the pin is set low. Or, you could connect the LED from A4 to ground, with the series resistor from A4 to +5V - this would then light when the pin was high - but it does waste current when the LED is turned off as the resistor is then directly across the HT rail.
