| i am building a big car using few high wiper motors.do i need to use seperate batteries for motors and the PIC circuit?or i can share one battery among all circuits? | |
| Using 2 separate batteries would be ideal. Whatever noise or spikes your motors generate, they would never interfere with the pic. But it is possible to run them all from the same battery | |
| today i connected a steper motor drive circuit shown below, that will forward(RA0 switch), reverse(RA1 switch) and stop(RA2 switch) but i faced problems. the program code is shown below. TRISB=0 TRISA=255 start: IF PORTA.0=0 Then Forwardmotor IF PORTA.1=0 Then Reversemotor IF PORTA.2=0 Then Stopmotor GoTo start Forwardmotor: PORTB.0=1 Pause 100 PORTB.1=1 Pause 100 PORTB.2=1 Pause 100 PORTB.3=1 Pause 100 IF PORTA.0=0 Then Forwardmotor GoTo start Reversemotor: PORTB.3=1 Pause 100 PORTB.2=1 Pause 100 PORTB.1=1 Pause 100 PORTB.0=1 Pause 100 IF PORTA.1=0 Then Reversemotor GoTo start Stopmotor: PORTB.0=0 PORTB.1=0 PORTB.2=0 PORTB.3=0 IF PORTA.2=0 Then Stopmotor GoTo start i get this from a book but when it was connected, so many problems i faced. (1)the output of 4050 hex buffer should be same as its inputs, that is, about 5V.but when i measure the output from the 4050, the outputs are only 1.3V only.i double check the connection but its correct.whats wrong with it? (2)is it when i make a pin HIGH,the pin will continue HIGH until i make it LOW?it is becasue when i measure the output pin(when i try to make the motor forward and reverse), all the pins are at HIGH level. (3)the circuit seems to draw more than 3A from the DC power supply.but the motor rating is only 2A.why? hope someone can solve my wuestion | |
| | (permalink) | |||
FWD REV 0001 1000 0010 0100 0100 0010 1000 0001 Repeat sequence until stopped. Your sequence is: FWD REV 0001 1000 0011 1100 0111 1110 1111 1111 Quote:
__________________ "Having to do with Motion Control" | ||||
