Old 22nd November 2003, 07:06 PM   (permalink)
Default PIC 16F84a to measure resistance for switch positions
Hi
I’m new to the wonderful world of PIC.
I want to build a circuit to detect which position a switch has been pushed. The switch has only one signal wire and a ground to measure the different positions.
The switch contains various smd resistor ladders. I need PIC 16F84A to looks at the various resistor ladders to know which direction the switch has been pushed.
I’ve measured the resistance for each of the position,
Left – 679 ohm
Right – 1536 ohm
Up – 471 ohm – this is the one I’m interested in
Down – 220 ohm
When the position is found I would like it to light up an LED indicator
I did try to measure the voltage using 5V supply, in all the position I get a reading of 5V. I need to measure the resistance
Any help would be appreciated greatly, code, circuit diagram etc
Thanks in advance
Ray
5neaker is offline   Reply With Quote
Old 22nd November 2003, 11:27 PM   (permalink)
This requires, *i think*, the command "Read ADC". This is an analog input for the PIC. As far as i know of this is the only command that can read analog inputs.
Off topic: Did any one see the world cup final between Australia and England??
www.winpicprog.co.uk - Great PIC language tutorials.
pike is offline   Reply With Quote
Old 23rd November 2003, 12:02 AM   (permalink)
Exo
Default Re: PIC 16F84a to measure resistance for switch positions
Originally Posted by 5neaker
Hi
Left – 679 ohm
Right – 1536 ohm
Down – 220 ohm
Thanks in advance
Ray
Yes, you'll need a PIC with a ADC, or an external ADC to work with your F84. The reason you measure 5V in all positions is because you're not getting any current trough those resistors. There will only be a voltage drop over a resistor when you make current go trough it.
add a 1K resistor between your switches output and GND. Now measure on the switch. Voltage will now change along with the resistance of the switch.
Exo is offline   Reply With Quote
Old 23rd November 2003, 04:15 PM   (permalink)
Originally Posted by Exo
Hi
Left – 679 <a href="#">ohm</a>
Right – 1536 <a href="#">ohm</a>
Up – 471 <a href="#">ohm</a> – this is the one I’m interested in
Down – 220 <a href="#">ohm</a>
Thanks in advance
Ray
Thanks Exo, could you send me any example external ADC work with the F84.
Old 23rd November 2003, 04:17 PM   (permalink)
Thanks for your reply Pike, no I never I heard tho, unlkucky for you guys
Old 23rd November 2003, 05:07 PM   (permalink)
Exo
I ofthen use a MCP3221 from microchip
http://www.microchip.com/1010/pline/...3221/index.htm
12 Bit A/D in a small SOT23 package. It uses I2C protocol wich only requires 2 wires between the converter and the pic
I2C code can be found on many places on the net, including nigel's site
Old 25th November 2003, 05:31 PM   (permalink)
You can do A/D in code with a 16F84A.
Here is where I read about it:
http://www.audiomulch.com/midipic/
And here is the code:
http://www.dontronics.com/psbpix/pot.html
Deagol_the_Dead is offline   Reply With Quote
