| I admit to posting this in another category group, but here it is - because of my background in programming and electronics I am determined to send a line of random data to program memory of the pic16f628 and then to READ it back confirming that the prgrmng was successful I am using qbasic lang sending sigs from the parallel port of a pc laptop with homebrew hardware I am utilizing 160 pgs of elect specs & 20 or more pgs programming spec's found on the internet I've noted some problems people have had with more sophisticated programming software so far I've changed my hardware (homebrew) twice when I program my one line of random data into pgm mem, I then try to read it back, mainly with an LED option to look at data appearing at the DATA pin when it is in output mode so far no signs of life with my PIC I have brought my mclr & pgm volt up to 5v (rather than just logic hi - say 3.5) I am proceeding on the basis that there are no MAX time constraints on the clock and data signals when I raise mclr & pgm I am assuming PC says zero as the loc for loading my data in my read pgm when I raise mclr & pgm I also assume I am at loc zero I am also assuming that config says 1 for low volt pgming are any of these assumptions faulty? Larry Keegan in Stoneham, MA, USA * | |
| *larrykeegan Joined: 09 Nov 2003 Total Posts: 3 * Re: my own programming of the pic16f628 Posted: 12-01-2003 12:54 PM to all concerned I was successful in loading in some random test data into my PIC16F628 at 10:30 PM EST on Saturday, Nov 29 and verifying the data using my own software (QBASIC) and hardware connected to the parallel port of an older PC laptop. My earlier attempts were uncsuccessful, since I was using the low voltage mode of programming. When I changed my hardware/software to use the high voltage mode, I achieved success. I also conclude that my PIC16F628 came from the manufacturer with the CONFIGURATION word set for permitting high voltage prgming only. A great feeling! Now I will proceed to entering a Hello World pgm in which I will hand assemble the instructions. It will probably blink an LED or turn an LED on when I close a switch to a separate port assigned as input. Sound OK? I seem to be having too much fun at age 75. Larry Keegan in Stoneham, MA | |
| Good for you! A blinking led program is the best way to start programming a PIC Keep up the good work, even at that young age! BR ldril | |
