| Hello I am an engineeering student, and have interest in 8051 microcontroller and am presently trying to write a pc at keyboard interfacing program in 8051 assembly. here i am reading the keyboard and converting it to its relevant ascii code and sending it to the uart its almost 10 days and i am not getting results i have made the circuit in the following way ... PORT 1 (P1.0) - connected to kbd clock line PORT 1 (P1.1) - connected to kbd data line PORT 1 (P3.0/RXD) - connected to Rxd of MAX232 PORT 1 (P3.1/TXD) - connected to Txd of MAX232 and while execution i am supposed to get the relevant ascii code for the pressed key , sent by the micro, for this i am running HYPER TERMINAL program, but the micro is not at all sending anythig i am including all the code to , could anyone tell me what could be the possible problem. ;################################################# ###################### ; ; KBD kbdata - uC PORT P3.1 (PIN 11) ; KBD kbclock - uC PORT P3.2 (PIN 12) ; KBD Xfer Check BIT - uC PORT P3.3 (PIN 13) ; KBD Download LED - uC PORT P3.6 (PIN 16) ; ;*********************** KEYBOARD EQUATES ************************************ shiftf bit 18h ; shift flag 0=no shift key is pressed,1=shift key is pressed kbdata equ p1.0 ; 8051 pin for KBD data line kbclock equ p1.1 ; 8051 pin for KBD clock line dnldled equ p1.5 ; led pin to denote a KBD transfer is in progress ; kbchk equ p3.3 ; KBD check bit, 0 indicates Display, 1 indicates KBDProg lastkey equ 60h ; last pressed KBD key curkey equ 61h ; current pressed KBD key org 0000h sjmp main ; jump to main program main: ;******************** POWER SUPPLY SETTLING LOOP ***************************** mov r0,#0ffh ;wait for power resetling time mov r1,#0ffh ;at the time of powering up mov r2,#0fh ploop: djnz r0,ploop djnz r1,ploop djnz r2,ploop CLR TR1 MOV SCON,#01011010B ;TI set indicates transmitter ready. ; mode 1,REN MOV TMOD,#00100001B ;Timer 1 is set to 8 bit auto reload mode orl pcon,#10000000B ; Set to double rate. mov th1,#0fah ; Set reload value (4800 baud after smod set) setb tr1 ; start timer. ;************************ KEYBOARD INITIALIZTION ***************************** setb dnldled clr kbclock ; clr kbclock to make it not to send any data clr kbdata ; clr kbdata to make not to check any key press clr shiftf ; clear shift flag to tell shift key is not pressed mov lastkey,#00h ; initialize the value of the last pressed key mov curkey,#00h ; initialize the value of the current pressed key ; JNB RI,$ ;Wait until character received. ; MOV A,SBUF ;Read input character. ; CLR RI ;Clear reception flag. ; ; CLR TI ;Clear interrupt flag. ; MOV SBUF,A ;Write out character. ; JNB TI,$ ;Wait until transmission completed. kbdprog: clr dnldled ; make p3.6 low to make the download led ON mov r7,#8 ; take data bit count in r7 mov curkey,#0 ; initialize curkey location to store the data from the kbd setb kbdata ; make kbd data line high (IDLE) setb kbclock ; make kbd clock line high (IDLE) chksbit: mov c,kbclock ; read clock line bit in carry flag jc chksbit ; chk if it is high than keep checking clock line till it goes low mov c,kbdata ; once it is low read the data line for a start bit jc chksbit ; if the start bit is high it is an invalid start ; bit so repeat theprocess to get the start bit again chkdbit: mov c,kbclock ; once a valid start bit is detected chk clock low for next data bit jc chkdbit ; keep checking till the clock line goes low mov c,kbdata ; once the clock goes low read the data bit mov a,curkey ; take the current key value in a rr a ; rotate it to right with carry so that mov acc.7,c mov curkey,a ; the LSB of key data will get into curkey djnz r7,chkdbit ; chk if 8 data bits have been read, if not then get next data bit chkpbit: mov c,kbclock ; read clock line for the last but one bit which jc chkpbit ; is the parity bit nop ; no parity checking chklbit: mov c,kbclock ; read clock line for the last bit which jc chklbit ; is the stop bit ; mov c,kbdata ; stop bit data ; jc vlddata ; if stop is a logic high than it is a valid key and data is valid ; sjmp krepeat ; if stop bit is low invalid stop bit so leave the key data vlddata: mov a,lastkey ; check if last scan code sent was an E0 than ; cjne a,#0e0h,chkcurk ; simply make the current scan code as the ; mov a,curkey ; get current key in acc ; mov lastkey,a ; store it in lastkey ; sjmp krepeat ;chkcurk: ; mov a,curkey ; check if the current scan code is an E0 ; cjne a,#0e0h,chkshift ; than make it as the last scan code ; mov lastkey,a ; sjmp krepeat ;chkshift: cjne a,#12h,noshift ; check if current scan code is a shift key mov a,lastkey cjne a,#0f0h,makesft ; yes than chk if the lastkey was an f0(break key) clr shiftf ; yes than its a shift key break so clear shift flag mov lastkey,#12h ; and make shift key as the lastkey sjmp kbdprog makesft: setb shiftf ; if lastkey is not F0 when curkey is shift key set shift flag mov lastkey,#12h ; store shift key as lastkey sjmp kbdprog noshift: cjne a,#0f0h,nobreak ; if current key is not shift key chk if it is a Break key(F0) mov lastkey,a ; yes than store it as the last key sjmp kbdprog nobreak: mov a,lastkey ; if non of the above key means may be a valid data key cjne a,#0f0h,no_f0 ; chk if last key was a break key mov lastkey,#0 ; yes than make 0 as the lastkey sjmp kbdprog no_f0: setb dnldled mov a,curkey ; if lastkey is not a break key than mov lastkey,a ; make the curkey as the lastkey jnb shiftf,loadunsft ; if shift key is not set load the unshifted data mov dptr,#shift ; if shift key is set load the shifted data sjmp getkeyval loadunsft: mov dptr,#unshift getkeyval: ; get the key value movc a,@a+dptr cjne a,#0,dataval ; if key value is 1Fh, not a valid data sjmp kbdprog ;**************************** STORE DATA TO I2C MEMORY ****************************** dataval: ; send this data to the console CLR TI ;Clear interrupt flag. MOV SBUF,A ;Write out character. JNB TI,$ ;Wait until transmission completed. ajmp kbdprog ;sendpc: ; CLR TI ;Clear interrupt flag. ; MOV SBUF,A ;Write out character. ; JNB TI,$ ;Wait until transmission completed. ; ret ;recvpc: ; JNB RI,$ ;Wait until character received. ; MOV A,SBUF ;Read input character. ; CLR RI ;Clear reception flag. ; ret ;s_init: ; ret ;************************************************* ********************** ; UNSHIFTED KEY CODES - Begin ;************************************************* ********************** unshift: db 0 ;0 db 0 ;1-F9 db 0 ;2 db 0 ;3-F5 db 0 ;4-F3 - denotes animation 3 db 0 ;5-F1 - denotes animation 1 db 0 ;6-F2 - denotes animation 2 db 0 ;7-F12 db 0 ;8- db 0 ;9-F10 db 0 ;A-F8 db 0 ;B-F6 db 0 ;C-F4 db 09h ;D-TAB db '`' ;E-`~ db 0 ;F- db 0 ;10- db 0 ;11-ALT(Left) db 0 ;12-SHIFT(Left) db 0 ;13- db 0 ;14-CTRL(Left) db 'q' ;15-Q db '1' ;16-1! db 0 ;17- db 0 ;18- db 0 ;19- db 'z' ;1A-Z db 's' ;1B-S db 'a' ;1C-A db 'w' ;1D-W db '2' ;1E-2@ db 0 ;1F- db 0 ;20- db 'c' ;21-C db 'x' ;22-X db 'd' ;23-D db 'e' ;24-E db '4' ;25-4$ db '3' ;26-3# db 0 ;27- db 0 ;28- db ' ' ;29-SPACE db 'v' ;2A-V db 'f' ;2B-F db 't' ;2C-T db 'r' ;2D-R db '5' ;2E-5% db 0 ;2F- db 0 ;30- db 'n' ;31-N db 'b' ;32-B db 'h' ;33-H db 'g' ;34-G db 'y' ;35-Y db '6' ;36-6^ db 0 ;37- db 0 ;38- db 0 ;39- db 'm' ;3A-M db 'j' ;3B-J db 'u' ;3C-U db '7' ;3D-7& db '8' ;3E-8* db 0 ;3F- db 0 ;40- db ',' ;41-,< db 'k' ;42-K db 'i' ;43-I db 'o' ;44-O db '0' ;45-0) db '9' ;46-9( db 0 ;47- db 0 ;48- db '.' ;49->. db '/' ;4A-/? db 'l' ;4B-L db ';' ;4C-;: db 'p' ;4D-P db '-' ;4E-_- db 0 ;4F- db 0 ;50- db ',' ;51- db 0 ;52-'" db 0 ;53- db '[' ;54-[{ db '=' ;55-+= db 0 ;56- db 0 ;57- db 0 ;58-CAPS db 0 ;59-SHIFT(Right) db 13 ;5A-ENTER db ']' ;5B-]} db 0 ;5C- db 92 ;5D-\| db 0 ;5E- db 0 ;5F- db 0 ;60- db 0 ;61- db 0 ;62- db 0 ;63- db 0 ;64- db 0 ;65- db 8 ;66-BACKSPACE db 0 ;67- db 0 ;68- db 0 ;69-1(Numeric) db 0 ;6A- db 0 ;6B-4(Numeric) db 0 ;6C-7(Numeric) db 0 ;6D- db 0 ;6E- db 0 ;6F- db 0 ;70-0(Numeric) db 127 ;71-.(Numeric) db 0 ;72-2(Numeric) db 0 ;73-5(Numeric) db 0 ;74-6(Numeric) db 27 ;75-8(Numeric) db 0 ;76-ESC db 0 ;77-NUM KEY db 0 ;78-F11 db '+' ;79-+(Numeric) db 0 ;7A-3(Numeric) db '-' ;7B--(Numeric) db '*' ;7C-*(Numeric) db 0 ;7D-9(Numeric) db 0 ;7E- db 0 ;7F- ; ;************************************************* ********************** ; UNSHIFTED KEY CODES - End ;************************************************* ********************** ;************************************************* ********************** ; SHIFTED KEY CODES - Begin ;************************************************* ********************** shift: db 0 ;0 db 0 ;1-F9 db 0 ;2 db 0 ;3-F5 db 0 ;4-F3 - denotes animation 3 db 0 ;5-F1 - denotes animation 1 db 0 ;6-F2 - denotes animation 2 db 0 ;7-F12 db 0 ;8- db 0 ;9-F10 db 0 ;A-F8 db 0 ;B-F6 db 0 ;C-F4 db 0 ;D-TAB db '~' ;E-`~ db 0 ;F- db 0 ;10- db 0 ;11-ALT(Left) db 0 ;12-SHIFT(Left) db 0 ;13- db 0 ;14-CTRL(Left) db 'Q' ;15-Q db '!' ;16-1! db 0 ;17- db 0 ;18- db 0 ;19- db 'Z' ;1A-Z db 'S' ;1B-S db 'A' ;1C-A db 'W' ;1D-W db '@' ;1E-2@ db 0 ;1F- db 0 ;20- db 'C' ;21-C db 'X' ;22-X db 'D' ;23-D db 'E' ;24-E db '$' ;25-4$ db '#' ;26-3# db 0 ;27- db 0 ;28- db ' ' ;29-SPACE db 'V' ;2A-V db 'F' ;2B-F db 'T' ;2C-T db 'R' ;2D-R db '%' ;2E-5% db 0 ;2F- db 0 ;30- db 'N' ;31-N db 'B' ;32-B db 'H' ;33-H db 'G' ;34-G db 'Y' ;35-Y db '^' ;36-6^ db 0 ;37- db 0 ;38- db 0 ;39- db 'M' ;3A-M db 'J' ;3B-J db 'U' ;3C-U db '&' ;3D-7& db '*' ;3E-8* db 0 ;3F- db 0 ;40- db '<' ;41-,< db 'K' ;42-K db 'I' ;43-I db 'O' ;44-O db ')' ;45-0) db '(' ;46-9( db 0 ;47- db 0 ;48- db '>' ;49->. db '?' ;4A-/? db 'L' ;4B-L db ':' ;4C-;: db 'P' ;4D-P db '_' ;4E-_- db 0 ;4F- db 0 ;50- db 0 ;51- db '"' ;52-'" db 0 ;53- db '{' ;54-[{ db '+' ;55-+= db 0 ;56- db 0 ;57- db 0 ;58-CAPS db 0 ;59-SHIFT(Right) db 13 ;5A-ENTER db '}' ;5B-]} db 0 ;5C- db '|' ;5D-\| db 0 ;5E- db 0 ;5F- db 0 ;60- db 0 ;61- db 0 ;62- db 0 ;63- db 0 ;64- db 0 ;65- db 8 ;66-BACKSPACE db 0 ;67- db 0 ;68- db '1' ;69-1(Numeric) db 0 ;6A- db '4' ;6B-4(Numeric) db '7' ;6C-7(Numeric) db 0 ;6D- db 0 ;6E- db 0 ;6F- db '0' ;70-0(Numeric) db '.' ;71-.(Numeric) db '2' ;72-2(Numeric) db '5' ;73-5(Numeric) db '6' ;74-6(Numeric) db '8' ;75-8(Numeric) db 27 ;76-ESC db 0 ;77-NUM KEY db 0 ;78-F11 db '+' ;79-+(Numeric) db '3' ;7A-3(Numeric) db '-' ;7B--(Numeric) db '*' ;7C-*(Numeric) db '9' ;7D-9(Numeric) db 0 ;7E- db 0 ;7F- ; ;************************************************* ********************** ; SHIFTED KEY CODES - End ;************************************************* ********************** END regards
__________________ hello | |
