| Hi all, I've built the PK2 LITE circuit and I've installed the picKIT2 application from Microchip web site. But, the application cann't identfy the Circuit, even when I plug-in the USB cable to the PC, the Win. doesn't recognize nothing, no sound or window is opened. where can I find an istructions how to use the PK2? Another question, the +5v in the circuit is comes from the USB or should I connect an external voltage source? TNX, your assistance will be appreciated. Avi. | |
| Did you program the 18F2550 ? Quote:
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | ||
| But, it still doesn't work.. my PC even doesn't recognize nothing when I plug in the USB cable to the PC | |
| All the USB needs to see a PK2 is a programmed 18f2550 a 20MHz crystal and caps , plus the USB connector and .47uF vreg cap. There are some versions of the schematc with the D+ & D- pins on the USB connector reversed. | |
| It's driving me crazy ... I've reproggramed the PIC18F4552, and I've checked the circuit again..everything is OK.. Windows doesn't detect nothing when I plug-in the usb. When I press SW1 (RB5 pull down) and plug-in the usb, then the Windows detects some un-recognized usb connection, and the "busy" LED blinks for a few sec. I really don't know what to do...pls hlp. TIA, Avi. | |
| @Bill of Blueroomelectronics, Sir, what is this PK2 LITE?Is it part of Junebug less tutor?
please check carefully. the USB B socket pin counting confuses, seeing from bottom or top. In USB A it can be clearly located pin adjacent to Ground is D+
__________________ Regards, Sarma. Last edited by mvs sarma; 10th October 2008 at 07:43 PM. | ||
| Pretty much it's the prototype PICkit2 built to the bare minimum without tutor. The D+ & D- lines were switched but the Junebug manual versions are correct. | |
| Thanks Bill
| ------------- Quote:
| Have you checked the D+ and D- lines, as Sarma suggested? One less problem to rule out. | |
| It doesn't require any special drivers; it'll appear as a simple HID device like a mouse. Run the PICKit2 standalone software to see if it sees it. You must have the .47uf cap and it must be a 20MHz crystal. The flashing red led should only flash if you hold down the button before plugging in the USB. How did you initially program the 18f2550? | |
| That's what I get for doing this on an iPhone. I'll have to see what an ART2003 is. | |
| GTP Programmer LITE | theo92 | Micro Controllers | 97 | 29th October 2008 01:32 PM |
| GTP USB Lite.... | jeremygaughan | Micro Controllers | 22 | 16th April 2008 02:09 PM |
| how to run Simulator in Proteus lite | nura100 | Micro Controllers | 0 | 17th February 2008 11:03 AM |
| Softrock-lite 80m V6.2 | forever99482 | Electronic Projects Design/Ideas/Reviews | 3 | 16th February 2008 11:35 AM |
| Sonnet Lite. | lord loh. | General Electronics Chat | 0 | 10th May 2006 06:21 PM |
