Is there any version of the PIC series that has an integrated D/A converter ( Analog outputs ) ?
I've not seen any, but many have hardware PWM which can be used, followed by a low-pass filter (which a normal D2A requires anyway).
Or you could use 8 pins to feed an R2R ladder, giving 8 bit resolution.
Both of those options will work but if the impedance of the load you're driving is low, you'll need a buffer.
Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer.
The PIC also needs to be powered from a stable 5V supply.
Cretan dsPIC33F have a built in stereo 16bit audio DAC.It even includes a buffer on the DAC.
Il give you shocking experience.
It looks expensive.
http://www.microchip.com/stellent/id...param=en534586Microchip Technology Announces Six New DSCs with 16-bit Audio DAC
Prices range from $3.67 to $4.18 each in 10,000-unit quantities.
