+ Reply to Thread
Page 2 of 3
First 1 2 3 Last
Results 16 to 30 of 43
Thread: Split Numbers
  1. #16
    ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,807
    Blog Entries
    13
    Quote Originally Posted by AtomSoft View Post
    EDIT: Ericgibbs you beat me to the question. BCD = binary-coded decimal. How would i send that. I know how to send data in but like if its
    7:09
    Just seen your edit,
    send 09 to addr 01h
    send 07 to addr 02h
    That is packed BCD,,, the upper nibble is the 'tens' and the lower nibble the 'units'
    17:59 hrs
    would be 17 to addr 02 [ 00010111]
    and 59 to addr 01 [ 01011001]
  2. #17
    AtomSoft Excellent AtomSoft Excellent AtomSoft Excellent AtomSoft Excellent AtomSoft Excellent AtomSoft Excellent AtomSoft Excellent AtomSoft Excellent
    Join Date
    Feb 2008
    Location
    Brooklyn, NY US
    Posts
    3,738
    This is my complete code. I got to skim through it to remove rough edges but it works fine for now...
    #include <p18f4525.h>
    #include <stdio.h>
    #include <delays.h>
    #pragma config WDT = OFF, OSC = HS, LVP = OFF
    //Funtions
    void main(void);
    void delay_s(unsigned char);
    void delay_ms(unsigned char);
    void delay_us(unsigned char);
    void i2c_byte(char addr);
    void i2c_start(void);
    void i2c_ack(void);
    char i2c_input(void);
    void i2c_clock(void);
    char rtc_read(char offset);
    char rtc_write(char offset, char data);
    void i2c_stop(void);
    void lcd_clr_line(char line);
    void lcd_init(void);
    void e_togg(void);
    void lcd_cmd(unsigned char cmd);
    void lcd_char(unsigned char tchar);
    void lcd_string(char *);
    void lcd_nybble(unsigned char data,char rs);
    void set_time(void);
    void get_buttons(char hm);
    // IO definitions
    #define SDA_PORT PORTCbits.RC4
    #define SDA LATCbits.LATC4
    #define SDA_TRIS TRISCbits.TRISC4
    #define SCL LATCbits.LATC3
    char slave_r = 0b11010001;
    char slave_w = 0b11010000;
    char Line1 = 0x80;            // 0x80 is the command hex to move cursor to 0 (Line 1 first character)
    char Line2 =  0xC0;            // 0xC0 is the command hex to move cursor to 64 (Line 2 first character)
    #define lcd_rs LATBbits.LATB4          // define LCD RS - PIN
    #define lcd_e LATBbits.LATB5           // define LCD E  - PIN
    #define lcd_DB7 LATBbits.LATB0         // define LCD Data Bit 7
    #define lcd_DB6 LATBbits.LATB1         // define LCD Data Bit 6
    #define lcd_DB5 LATBbits.LATB2         // define LCD Data Bit 5
    #define lcd_DB4 LATBbits.LATB3         // define LCD Data Bit 4
    #define up_btn PORTAbits.RA0
    #define set_btn PORTAbits.RA1
    char time[9] = " ";
    char s_time[9] = " ";
    char seconds;
    char minutes;
    char hours;
    char g_hr_high, g_hr_low;
    char g_min_high, g_min_low;
    char stringA[5] = {'H','o','u','r',0};
    char stringB[8] = {'M','i','n','u','t','e','s',0};
    void main(void)
        char sec_low, sec_high;
        char min_low, min_high;
        char hr_low, hr_high;
        char tmp,tmp2;
        ADCON1 = 0b00001111;
        TRISC = 0x00;
        TRISB = 0x00;
        TRISA = 0x00;
        TRISAbits.TRISA0 = 1;
        TRISAbits.TRISA1 = 1;
        lcd_init();                             //Launch Initialize function
        while(1){
            for(tmp=0;tmp<9;tmp++){
                time[tmp] = 0x30;
                s_time[tmp] = 0x30;
            time[2] = 0x3A;
            time[5] = 0x3A;
            time[8] = 0;
            s_time[1] = 0x31;
            s_time[2] = 0x3A;
            s_time[5] = 0x3A;
            s_time[8] = 0;
            seconds = rtc_read(0x00);
            minutes = rtc_read(0x01);
            hours = rtc_read(0x02);
            time[7] = sec_low = (seconds & 0x0F) + '0';
            time[6] = sec_high = ((seconds>>4) & 0x0F) + '0';
            time[4] = min_low = (minutes & 0x0F) + '0';
            time[3] = min_high = ((minutes>>4) & 0x0F) + '0';
            time[1] = hr_low = (hours & 0x0F) + '0';
            time[0] = hr_high = ((hours>>4) & 0x0F) + '0';
    	    lcd_cmd(Line1);                         //Set to Line 1
            delay_ms(1);
    	    lcd_string(time);                     //Send our string.
            delay_ms(50);
            if(set_btn){
                set_time();
                delay_ms(50);
                rtc_write(0x00,0x00);
                s_time[0]-= 0x30;
                s_time[1]-= 0x30;
                s_time[3]-= 0x30;
                s_time[4]-= 0x30;
                tmp2 = (s_time[3]<<4) + s_time[4];
                rtc_write(0x01,tmp2);
                tmp2 = (s_time[0]<<4) + s_time[1];
                rtc_write(0x02,tmp2);
                lcd_clr_line(1);
                delay_ms(10);
                lcd_clr_line(0);
                delay_ms(10);
    void delay_s(unsigned char x)
        char var1;
    	for(var1=0;var1<x;var1++)
            Delay10KTCYx(500);    //5,000,000 cycles = 1 second
    void delay_ms(unsigned char x)
        char var1;
            Delay1KTCYx(5);    //5,000 cycles = 1 us
    void delay_us(unsigned char x)
        char var1;
            Delay1TCY();    //5 cycle = 1 us
            Delay1TCY();
            Delay1TCY();
            Delay1TCY();
            Delay1TCY();
        SCL = 1;
        delay_us(5);
        SCL = 0;
    char rtc_write(char offset, char data){
        char temp;
        i2c_start();                //Start
        i2c_byte(slave_w);          //Slave Byte
        i2c_ack();                  //ACK
        i2c_byte(offset);           //Address Offset
        i2c_ack();                  //ACK
        i2c_byte(data);          //Slave Byte
        i2c_ack();                  //ACK
        i2c_stop;                    //Stop
        return temp;
    char rtc_read(char offset){
        char temp;
        i2c_ack();                  //ACK
        i2c_ack();                  //ACK
        i2c_byte(slave_r);          //Slave Byte
        i2c_ack();                  //ACK
        temp = i2c_input();         //Get Data
        i2c_ack();                  //ACK
        i2c_stop;                    //Stop
        return temp;
    void i2c_start(void){
        SDA_TRIS=0;   //SDA Output
        SCL=0;        //Clock Low
    //Start - 5us
        SDA=1;        //SDA High
        SCL=1;        //Clock high
        delay_us(4);
        SDA=0;        //SDA Low
        delay_us(1);
        SCL=0;        //Clock Low
    void i2c_byte(char addr){
        char bl;
        for(bl=0;bl<8;bl++){
            if((addr & 0x80) != 0)
                SDA = 1;
            else
                SDA = 0;
        i2c_clock();
        addr=addr<<1;
    void i2c_ack(void){
        SDA_TRIS = 1;   //SDA Input
        i2c_clock();
        delay_us(5);
        //while(SDA);
        SDA_TRIS = 0;
    char i2c_input(void){
        char temp;
        char i;
        SDA_TRIS = 1;
        temp=0;
        i = 0;
        for(i=0;i<8;i++){
            temp=temp<<1;
            if(SDA_PORT)
                temp|=1;
            i2c_clock();
        SDA_TRIS = 0;
        return temp;
    void i2c_stop(void){
        SDA = 0;
        SCL = 1;
        delay_us(3);
        SDA = 1;
        SCL = 0;
    //              Time Functions
    void set_time(void){
        lcd_clr_line(0);
        delay_ms(100);
        lcd_clr_line(1);
        delay_ms(100);
        delay_ms(100);
        lcd_string(stringA);                     //Send our string.
        delay_ms(100);
        while(!set_btn){
            delay_ms(50);
            if(up_btn)
                get_buttons(1);
        lcd_clr_line(0);
        delay_ms(100);
        lcd_clr_line(1);
        delay_ms(100);
        delay_ms(100);
        lcd_string(stringB);                     //Send our string.
        delay_ms(100);
        while(!set_btn){
            delay_ms(50);
            if(up_btn){
                get_buttons(0);
    void get_buttons(char hm){
    if (hm == 1){
        if(s_time[0] == 0x31){
            if(s_time[1] < 0x32){
                 s_time[1]++;
            } else {
                 s_time[1] = 0x31;
                 s_time[0] = 0x30;
        } else {
            s_time[1]++;
            if(s_time[1] > 0x39){
                s_time[1] = 0x31;
                s_time[0]++;
                if(s_time[0] == 0x32)
                    s_time[0] = 0x30;
    } else {
       s_time[4]++;
        if(s_time[4] > 0x39){
            s_time[4] = 0x30;
            if(s_time[3] == 0x35)
                s_time[3] = 0x30;
            else
                s_time[3]++;
        lcd_clr_line(1);
        delay_ms(50);
        lcd_cmd(Line2);                         //Set to Line 1
        delay_ms(50);
        lcd_string(s_time);                     //Send our string.
        delay_ms(60);
    //                LCD Stuff
    //This is our clear line command.
        char tline;                             //The line to clear variable
        char x;                                 //loop variable
        if(line==0)                             //set the variable value based on line
            tline=0x80;                         // 0 = Line 1
        else
            tline=0xA8;                         // 1 = Line 2
        lcd_cmd(tline);                         // Send command to jump to beggining of line (1/2)
        delay_ms(1);
        for(x=0;x<40;x++){                      // Loop through all 40 chars of line (even tho 16 are viewable)
            lcd_char(0x20);                     // Send Blank Character
            delay_us(500);
        lcd_cmd(tline);                         // Go back to beggining of line
        delay_ms(1);
    void lcd_init(void)
    {                                       //This is our lcd initialization function
        delay_ms(20);                       // Wait at least 16 mS after powerup
    	lcd_nybble(0x03,0);                 // send 0x03 cmd 3 times to initialize
    	delay_us(160);
    	e_togg();                       // Since 0x03 nybble is on the port already
    	delay_us(160);                      // we just toggle 2 more times
    	e_togg();
    	delay_us(160);
    	lcd_nybble(0x02,0);                 //Enable 4 bit mode
    	delay_us(160);
    	lcd_cmd(0x28);			    //set 4-bit mode and 2 lines @ 5x7
    	delay_us(160);
    	lcd_cmd(0x10);			    //cursor move & shift left
    	delay_us(160);
    	lcd_cmd(0x06);			    //entry mode = increment
    	delay_us(160);
    	lcd_cmd(0x0d);			    //display on - cursor blink on
    	delay_us(160);
    	lcd_cmd(0x01);			    //clear display
    	delay_us(160);
        delay_ms(5);
    void e_togg(void){
        lcd_e = 1;
        lcd_e = 0;
    void lcd_cmd(unsigned char letter)
    //This is our Command Function
    //The RS is set to 0 to signify this is a command
    	unsigned char temp;             //Our temp Variable
    	temp=letter;                    //move letter to temp
    	temp=temp>>4;                   //shift temp to right by 4
    	lcd_nybble(temp,0);             //send the 4 out
    	temp=temp&0x0f;                 //and out first 4
    	lcd_nybble(temp,0);             //send out last 4
    void lcd_char(unsigned char letter)
    //This is the same as the lcd_cmd function except
    //that is sets RS to 1 telling the lcd this is characters
    	unsigned char temp;
    	temp=letter;
    	temp=temp>>4;
    	lcd_nybble(temp,1);
    	temp=letter;
    	temp=temp&0x0f;
    	lcd_nybble(temp,1);
    void lcd_string(char *senpoint)
    	while(*senpoint != '\0')            //While we havent seen a \0 (esc) go on
    	    lcd_char(*senpoint);            //send 1st char to our char function
    	    senpoint++;                     //send next
    void lcd_nybble(unsigned char nyb,char rs)
    	char i;
            char x;
            lcd_rs = rs;                    //Set RS Pin (defined in header file)
    	for(i=0;i<4;i++){		//Loop through nybble
            if((nyb & 0x08) != 0)           //AND the nybble to 8
    	    x=1;                        //if the AND == 1 set x
    	else
     	    x=0;                        //if the AND == 0 clear x
            if(i==0)                    //select RA3:RA0 and set/clear pins
                lcd_DB7=x;
            if(i==1)
                lcd_DB6=x;
            if(i==2)
                lcd_DB5=x;
            if(i==3)
                lcd_DB4=x;
            nyb=nyb<<1;                     //shift nybble to the left by 1 (4 times total)
    	e_togg();                   //toggle E pin (defined in header file)
    EDIT:
    How do i split this file into various c files like :
    1. i2c.c
    2. rtc.c
    3. lcd.c
    AtomSofts eBay Store
    AtomSoftTech: C18 TIPS & TRICKS v9 PDF
    My Name: Jason Lopez
    My BLOG | My YouTube Videos!
    My Favorite Store:
    dipmicro Electronics
    Trading and Selling...? Check out Dipmicro Trading/Selling Forum:
    Electronic Components & Tools Exchange
  3. #18
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,807
    Blog Entries
    13
    hi Atom,
    Like to help but I dont do 'C' I'm a Assemblersaurus.
  4. #19
    Join Date
    Feb 2008
    Location
    Brooklyn, NY US
    Posts
    3,738
    heh thanks tho you helped
    My Favorite Store:
  5. #20
    philba Good philba Good philba Good
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    1,887
    I am assuming you are using the microchip IDE.
    You split the file apart in to .c files using your favorite text editor and then add each file to the project. mplab knows to compile each file and add them to the link line. It's pretty easy. Sorry I can't give you the exact directions - I don't have it on this machine.
    For the header stuff (prototypes, defines, ...), I stick all those in a .h file and use include. Add the .h files to your project so it will know to recompile the .c files when they change. You might need to use externs to access global variables across modules. It's not hard at all and makes it easier to share code among different projects.
  6. #21
    Join Date
    Feb 2008
    Location
    Brooklyn, NY US
    Posts
    3,738
    I didn't know it will automatically link them ... that's cool. I don't want to be a bother but im away from my pc right now and can't check it... how would I make/use externs?
    My Favorite Store:
  7. #22
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    1,887
    You use extern to define a reference to a variable declared outside of the module.
    extern int foo;
    in one module, it needs to be declared.
    int foo;
    any C Reference will give you the details and some PIC compilers do things differently so check the manual.
  8. #23
    Join Date
    Feb 2008
    Location
    Brooklyn, NY US
    Posts
    3,738
    Thanks ill be sure to double check the manual. Ill post soon on how it went... thanks again to all.
    My Favorite Store:
  9. #24
    Join Date
    Feb 2008
    Location
    Brooklyn, NY US
    Posts
    3,738
    for some reason i get errors... Some questions:
    1. Do i have to include header in each c file?
    2. How do i extern a #define?
    Can someone show me some examples of this. I hate the c18 manual it sux. No good info in it.
    3. Anyone got a better resource than the c18 manual?
    My Favorite Store:
  10. #25
    3v0
    3v0 is offline
    3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,463
    Blog Entries
    11
    If I remember the rest of the thread you are doing separate compiles then linking. If a C file needs info from a header file you have to include the header file. Well written header files have a check in the form of #ifdef myFlagName that will prevent them from generating errors if included twice.
    You do not do extern #defines, you include the header file in which they exist.
    The things you are talking about are general C related issues. So the BoostC or C18 linker and complier docs would be more helpful. Maybe a general C book like K&R C. Most of what you want is going to be buried in a lot of other stuff. Maybe a section on linking objects would have some of it.
    I would like to provide more info but I have to run. Mike or one of the others can fill in the details, if not I will be back in a few hours.
    BCHS/3v0's Tutorials
  11. #26
    Join Date
    Feb 2008
    Location
    Brooklyn, NY US
    Posts
    3,738
    thanks...i think i understand what your talking about now. Ill give it a go and will post results.
    My Favorite Store:
  12. #27
    Join Date
    Mar 2006
    Location
    Seattle
    Posts
    1,887
    there is no such thing as an extern for #defines. An extern is a message for the linker, #define is actually a preprocessor directive that caused the defined string to textually substituted before the compiler is actually run. #defined names actually don't exist to the compiler itself. By the way, all # lines are preprocessor directives. Even #include...
    Take all your #defines and put them in .h files. Separate them into logical groupings - serial I/O ones in serial.h, LCD ones in lcd.h. I would include the function prototypes in the relevant .h. Then #include the relevant .h files in the .c files that reference them. I'd put together a simple example but I've got to go earn a buck...
  13. #28
    Join Date
    Feb 2008
    Location
    Brooklyn, NY US
    Posts
    3,738
    Thanks a bunch... that seems to make sense.. I mean organizing it. That's the whole reason I want to split it so I can reuse it without issue. Thanks again... I make a buck tommorow.(off today)
    My Favorite Store:
  14. #29
    Join Date
    Feb 2008
    Location
    Brooklyn, NY US
    Posts
    3,738
    here is a pic of it still working on adding 1 more button tho.
    btn01 = mode/enter
    btn02 = change
    btn03 = enter
    i want to put enter button seperate lol
    My Favorite Store:
  15. #30
    Mike, K8LH Excellent Mike, K8LH Excellent Mike, K8LH Excellent Mike, K8LH Excellent Mike, K8LH Excellent Mike, K8LH Excellent Mike, K8LH Excellent
    Join Date
    Jan 2005
    Location
    Michigan, USA
    Posts
    2,519
    I don't think you're using a big enough PIC. Just kidding (grin). Looks nice.
    Have fun... Mike
+ Reply to Thread
Page 2 of 3
First 1 2 3 Last
  1. Split Charger.
    By hackableFM in forum General Electronics Chat
    Latest: 18th March 2008, 08:29 AM
  2. zig unit for vw split screen
    By smithy in forum Electronic Projects Design/Ideas/Reviews
    Latest: 31st August 2005, 05:31 PM
  3. Split Supply
    By grrr_arrghh in forum General Electronics Chat
    Latest: 3rd May 2004, 03:57 PM
  4. Need a split power supply (+ and -)
    By TheDude1888 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 23rd February 2004, 10:01 AM
  5. Split Charger
    By jezzz in forum Electronic Projects Design/Ideas/Reviews
    Latest: 12th April 2003, 07:13 AM
Tags for this Thread
