Old 3rd September 2008, 08:17 PM   #1
Default ps/2, pic external interrupt problem
helllllllllo eveybody
i have this project where the use of ps2 mouse is required and i am having real problem interfacing it to the micro, i am using the 16f877a.
the clock of the ps/2 is pulled high by a pull-up resistor and connected to the external interrupt pin B0.
the data pin is connected to pin D2 and also pulled high
now i am able to monitor the signal using the pickit2, when the mouse is powered up it sends 0xAA 0x00 bytes, i am able to confirm that. here is the img
the problem is when i try read the signal using the microcontroller i faild, even when simply just trying to count the clock pulses at PIN B0 during mouse power up
#int_EXT
void  EXT_isr(void)
   pulses++;
void main()
   pulses = 0;
   .......PIC initialization code.........
   ext_int_edge( H_TO_L ); //track high to low transitions on pin
   enable_interrupts(INT_EXT);// enable external interrupt
   enable_interrupts(GLOBAL);
   set_tris_b(0xff);
   while(true)
      printf("pulses: %u\r\n",pulses);
      delay_ms(500);
the output of the code:
pulses: 1
where it should be 22 i belive
here is what i tried to do :
- remove the pickit2 while the pic is doing its job trying to count them pulses
- remove the pullup resistors
- enable/disable portb weak pull ups
- re-enable the ext_int at the ISR
- simulating with protues isis gives correct result !!!
i dont know whats wrong + ive been trying to solve it for 2 days so any suggestions are highly appreciated !!
thanks for reading.
v1r05 is offline
Old 4th September 2008, 02:08 AM   #2
Post all your code instead of where you think the problem is. A few questions/suggestions, is the wdt turned off, how and where is pulses defined, which compiler are you using.
Pommie is offline
Old 11th September 2008, 01:49 PM   #3
ok this the code
#include <16F877A.h>
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOBROWNOUT               //No brownout reset
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOCPD                    //No EE protection
#FUSES NOWRT                    //Program memory not write protected
#use delay(clock=20000000)
#use rs232(baud=57600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#use fast_io (B)
volatile unsigned int x;
#int_EXT
void  EXT_isr(void)
   disable_interrupts(INT_EXT);
   x++;
   clear_interrupt(INT_EXT);
void main()
   x =0;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DISABLED,0,1);
   setup_comparator(NC_NC_NC_NC);
   setup_vref(FALSE);
   port_b_pullups (false);
   while(1)
      printf("%u\r\n",x);
      delay_ms(1000);
this driving me crazy please help...
v1r05 is offline
external, interrupt, pic, problem, ps or 2
PIC 16F877 external Interrupt Problem!!! mesamune80 Micro Controllers 6 24th June 2008 02:18 AM
RB0 External Interrupt Problem Suraj143 Micro Controllers 6 30th August 2007 07:26 AM
how to handle external interrupt anch Micro Controllers 1 3rd June 2006 03:21 AM
external interrupt neelam29 Micro Controllers 4 11th March 2006 02:50 PM
external interrupt address neelam29 Micro Controllers 4 25th February 2006 03:00 AM
