Old 30th August 2008, 04:03 AM   (permalink)
Default Using 'continue' in Hi-Tech C
I'm now learning to use Hi-Tech C. Previously, I use C18 compiler.
In Hi-Tech C, I'm trying to poll the GODONE bit in ADC. In the example, they use
while (GODONE) continue;
Is there any difference if I use while (GODONE); instead (without 'continue')? When I use the second one, it is able to build well without any error.
Please advice. Thanks.
MrNobody is offline
Old 30th August 2008, 05:51 AM   (permalink)
while(GODONE);
is the way it's done. Standard practice. You can also do
while(GODONE){}
if you want.
futz is online now
Old 30th August 2008, 06:00 AM   (permalink)
Futz is right.
Continue works within loops where its effect is to force an immediate jump to the loop control statement. Lots of info on the web see http://cplus.about.com/od/learningc/...ssonfive_3.htm
3v0 is online now
Old 30th August 2008, 11:20 AM   (permalink)
Thanks for the explanation.
MrNobody is offline
Old 30th August 2008, 04:35 PM   (permalink)
I would either continue to use the continue statement or use the empty bracket set as the simple semi-colon terminator seems a little ambiguous, at least to me. Seeing as how all three lines of code perform the same function you can do it any which way you want.
straight answer, har har."
Sceadwian is offline
Old 30th August 2008, 04:51 PM   (permalink)
I would use the semi colon version everytime. It is only ambiguous if you are not really familiar with C.
Pommie is offline
Old 30th August 2008, 06:24 PM   (permalink)
Agreed, although I slightly prefer the empty-bracket version--probably just because a professor I liked 12 years ago used it. It's unambiguous even if you are not very familiar with C.
The "continue" version I would not use or recommend. Without the enclosing braces, the semantics might get tricky for the parser. Sounds like that might be the case with Hi-Tech C.
Torben
Curiosity was framed. Ignorance killed the cat.
Torben is offline
Old 30th August 2008, 07:27 PM   (permalink)
well, I always like only the semicolons, looks really simple!!
who knows, the Hi-tech people might be using 'continue' to improve radability!! but it can be achieved better with a comment! No need for continue there..
http://dharmanitech.blogspot.com
CCD is offline
Old 30th August 2008, 07:43 PM   (permalink)
You say potato, I say potato. Wait... that little phrase doesn't work in text =\
Old 30th August 2008, 07:44 PM   (permalink)
Yeah, as far as ';' vs '{}' it's. . .er. . .6 of one, half a dozen of the other (there, found one for text!) .
The 'continue' one just looks suspicious to me, although gcc happily compiles it in ANSI mode. Huh.
Torben
Torben is offline
Old 30th August 2008, 08:30 PM   (permalink)
I guess it's 'safer' to explicitly refer to the continue rather than rely on the compiler knowing what to do with it. It's a whole lot of gray area =)
Old 31st August 2008, 05:29 AM   (permalink)
I'd say it's a pretty broken compiler that gets while(GODONE); wrong, as long as GODONE is considered volatile (which I'm pretty sure it is).
Note that this may not work with a declared variable unless it was declared as volatile. An optimizer may get overzealous in the following case
unsigned char foo;
foo = 0;
while(foo);
philba is offline
Old 31st August 2008, 08:14 AM   (permalink)
Perhaps they use the continue as a means to avoid optimisation simply removing the entire statement.
I have seen things happen with optimisers like that with simple tests. It's always best to make sure the controlling statement uses a variable declared as volatile, especially if it can be changed by external influences, IRQ's for instance.
Ray
zathras is offline
Old 1st September 2008, 12:14 AM   (permalink)
unsigned char foo;
foo = 0;
while(foo);
Oh.. umm.. thanks.. i didn't know that.. I'll try to remember to use 'continue' next time i use a non volatile variable.. If not i'll be wondering why my code is not working as it should. Thanks alot.
MrNobody is offline
New robotics tech mous3 Robotics Chat 0 31st July 2008 03:07 AM
ICD2 woes continue... Hank Fletcher Micro Controllers 12 16th June 2008 01:55 PM
Greetings Electro-tech. xl5 Chit-Chat 4 29th December 2007 07:06 PM
a solution for a bell to continue playing music after releasing switch Fahime General Electronics Chat 3 9th November 2006 11:26 AM
Electro-tech map!! jrz126 Chit-Chat 83 12th January 2006 11:43 AM
