Old 18th August 2008, 08:14 AM   (permalink)
Default IR TX / RX with 16F628
Hi everybody,
I am working on a project for controlling some devices with a remote controller which use NEC protocol. I have written RX codes in CCS using the timers. I have tried to catch fall and rise points to generate two data column and a checksum. After I setup and execute the timer, I wait for signal go to low with while(IR_PIN). But pic doesn't response until this line. It always stays in eternal loop in spite of it's logic value becomes zero.
I confused up.
NST is offline
Old 18th August 2008, 08:51 AM   (permalink)
Have you turned off the comparators CMCON=7;?
Is the pin set to input?
Is IR_PIN defined as a single bit?
A bit more information and some code would be useful.
Pommie is offline
Old 18th August 2008, 01:07 PM   (permalink)
Thank you Mike.
Yes I turned the comparators off. Here is my code;
#include <16f628a.h>
#fuses NOWDT, INTRC_IO, PUT, NOPROTECT, MCLR
#use delay (clock=4000000) //4 MHZ
#byte CMCON=0x07;
#define  IR_PIN  PIN_B0
unsigned char bitcount;
int32 ir_tempbyte_hi;
int16 ir_tempbyte_lo;
int16 headp,heads,rise,fall;
void ir_read(void);
void ir_get_rise(void);
void ir_get_fall(void);
void ir_build_bytes(void);
#int_ext
void  ext_int ()
   ir_read();
void ir_read(void)
   ir_tempbyte_hi=0;
   ir_tempbyte_lo=0;
   while(IR_PIN); // //Wait for minimal pre which stays low
   ir_get_rise(); // Get headp & heads to see what protocol it is
   headp=rise;
   ir_get_fall();
   heads=fall;
   if ((headp>8800)&&(headp<9090)&&(heads>4200)&&(heads<4570)) // We got NEC Start Sequence
      output_high(PIN_A2);
      ir_build_bytes(); // Now trying to read data bits
   else
   output_high(PIN_A7);
   setup_counters(RTCC_INTERNAL,RTCC_DIV_1);    // Get high
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
   set_timer1(0);
   while(!IR_PIN); // Wait for signal to go high
   rise = get_timer1();
   delay_ms(1000);
   output_low(PIN_A7);
   output_high(PIN_A6);
   setup_counters(RTCC_INTERNAL,RTCC_DIV_1);   // Get low
   set_timer1(0);
   while(IR_PIN);          // Wait for signal to go low
   fall = get_timer1();
   delay_ms(1000);
   output_low(PIN_A6);
   for (bitcount=0;bitcount!=32;bitcount++)
      ir_get_rise();
      ir_get_fall();
      if ((rise>450)&&(rise<650)&&(fall>1400)&&(fall<1655))
         ir_tempbyte_hi|=1; // bit=1
      else if ((rise>450)&&(rise<650)&&(fall>390)&&(fall<600)){;} // bit=0
      else return; // Byte Check Fault
   if (bitcount<31){ir_tempbyte_hi<<=1;}  // Don't shift last bit
   if (bitcount==32){output_high(PIN_A2);} // reception is valid
void main ()
   setup_CCP1(CCP_OFF);            // CCP1 unit outbound
   ext_int_edge(H_TO_L);           // INT_EXT is High to Low
   setup_timer_0(t1_disabled);
   setup_timer_1(t2_disabled);
   enable_interrupts(INT_EXT);     // INT_EXT interrupt inbound
   enable_interrupts(GLOBAL);      // All interrupts inbound
   while(1); //Stand by
NST is offline
Old 18th August 2008, 01:56 PM   (permalink)
I'm afraid I'm not familiar with the compiler you are using. I assume it is the CCS compiler as it appears to clear the interrupt flags for you.
One thing I notice from your code is your ISR calls ir_read which calls ir_get_rise which has a 1 second delay in it!
If it helps, here is some code I wrote in C18 which reads a sony code
#define IR_in   PORTAbits.RA6
#define IR_tris TRISAbits.TRISA6
unsigned char GetPulse(void){
unsigned char count;
    count=0;
    IR_tris=1;
    while(IR_in==1);
    while(IR_in==0){
        count++;
        Delay100TCYx(1);   //50uS assumes 8MHz
    return count;
void GetIR(char *cmd,char *dev){
char i;
    *cmd=0;
    *dev=0;
    while(GetPulse()<40);    //wait for start pulse
    for(i=0;i<7;i++){
        *cmd=*cmd>>1;
        if(GetPulse()>18)
            *cmd|=0x40;
    for(i=0;i<5;i++){
        *dev=*dev>>1;
        if(GetPulse()>18)
            *dev|=0x10;
Pommie is offline
Old 18th August 2008, 02:51 PM   (permalink)
One thing I notice is that you haven't disabled Low Voltage Programming in your config, add NOLVP to your fuses statement.
Also as Pommie points out, interrupts should be short and sweet. Perhaps a better method is to set a flag in the isr, then in your main check to see if the flag is set and if so, go to your subroutine from there.
BeeBop is offline
Old 18th August 2008, 04:02 PM   (permalink)
Thank you very much.
NST is offline
JDM and 16F628 patroclus Micro Controllers 15 22nd November 2008 06:03 PM
16f628 OY2L Micro Controllers 16 9th July 2008 10:28 AM
16F628 help W8TZ Micro Controllers 4 18th September 2007 12:37 PM
16F628 2-2-1 AZdave Micro Controllers 0 24th December 2004 10:09 PM
16F628 PWM Fletcher Micro Controllers 7 6th September 2004 02:31 PM
