Old 17th August 2008, 12:04 PM   (permalink)
Default Saving data to eeprom
Does anyone know how to store data to EEPROM?
I am currenly using PIC18F2620.
apricot_star is offline
Old 17th August 2008, 12:17 PM   (permalink)
Have a read of this thread.
Pommie is offline
Old 17th August 2008, 12:32 PM   (permalink)
Thank for the reply.
Actually, i know how is the routine like to write and read to eeprom. My problem is that i dunnno how to implement it. I suppose to store the calibration value of light sensor to the eeprom so that my main program will know it when my device is first power up. I just don't understand how is the things work from saving the value and read the value.
Here is the example of what have my friend done:
# define FCIN_ADDR 0x00
result= ReadEeprom(FCIN_ADDR);
result<<=8; // i dun understand why must it shift by 8
tem=ReadEeprom(FCIN_ADDR+1);// why must it increment by1
result+=tem;
Regards
Old 17th August 2008, 01:26 PM   (permalink)
Why not ask your friend?
Mike, K8LH is offline
Old 17th August 2008, 02:43 PM   (permalink)
//Reads the high byte and shifts it 8 to put it in the high byte of results.
result<<=8;
// Read low byte and add it to the result which contains the high byte
result+=tem;
Regards
The above code reads a 16 bit value from the EEPROM 8 bits at a time.
Given that you did not understand what the <<= operator was you either need
to learn C or have you friend help you.
3v0 is online now
Old 18th August 2008, 02:02 AM   (permalink)
Thanks, i got it now =)
saving value without eeprom PIC16F72? neelam29 Micro Controllers 1 12th January 2008 08:06 AM
Data EEPROM of PIC questions bananasiong Micro Controllers 35 25th July 2007 10:25 AM
Writing Data to the EEPROM Electrix Micro Controllers 2 31st August 2005 07:39 AM
EEPROM data corruption StupidDum Micro Controllers 0 28th September 2004 05:01 AM
PIC 16f876 data eeprom write SuperBud Micro Controllers 3 22nd October 2003 02:15 AM
