+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 20
Thread: switching
  1. #1
    chandu13 Newbie
    Join Date
    Aug 2006
    Posts
    98
    Default switching
    Hay
    I want control the 400mA, 24V load using PWM
    Which device is preferable for switching applications TRANSISTER or MOSFET?
    Please suggest TRANSISTER or MOSFET for the above application
    Regards
    chandu
  2. #2
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,029
    You didn't say whether you're switching the high or low side or the frequency. I'll assue you're switching the low side as it's much easier.
    BC548, BC337, IRL540.
    if I know the answer.
  3. #3
    chandu13 Newbie
    Join Date
    Aug 2006
    Posts
    98
    Default switching
    Thanks for the reply
    I am controlling the 400mA, 24V proportional solenoid valve using PWM
    I can generate any frequency from 100Hz to 14MHz using LPC2106
    So what frequency range I can use for above application
    What are the considerations for switching application?
    Regards
    chandu
  4. #4
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,029
    It doesn't really matter what the frequency is. It needs to be high enough for the current to remain circulating in the solenoid when ther transistor is off an low enough to prevent switching losses from being excessive. I'd recommend about 100kHz but it really depends on the inductance of the coil.
  5. #5
    chandu13 Newbie
    Join Date
    Aug 2006
    Posts
    98
    Default switching
    Hay
    I am using Series SVP Proportioning Solenoid Valve from
    http://www.dwyer-inst.com/PDF_files/SVP_iom.pdf
    In the pdf they have not mentioned any information regarding the inductance & switching frequency
    Presently I am using 1Kz PWM & switching transistor as TIP122,
    TIP122 can useful for only 3KHz (lower switching applications)
    Regards
    chandu
  6. #6
    sachin.kolkar Bad
    Join Date
    Dec 2007
    Location
    BANGALORE,INDIA
    Posts
    60
    Smile
    use transistor , or optotransistor , but for the solonoid valve (its inductive load) it won't work properly...
    my suggestion is thatgo for ssr's for switsching......
    how would u generate 100Hz PWM pulse & what is ur clock frequency......
    400mA ,24 V is it a dc?
    hm:
  7. #7
    Arkham00 Newbie
    Join Date
    Jul 2007
    Location
    Italy
    Posts
    88
    Default Driving a proportional valve
    Quote Originally Posted by chandu13 View Post
    Reading the datasheet of the valve, I think you should not feed it with a PWM signal but with a variable DC voltage. Because of the nature of the proportional valve, the PWM approach may bring to very poor linear control of the flow.
    I suggest you use the PWM output of the micro to feed a low-pass filter (active or passive) that drivers a power op-amp to drive the valve.
    Here is a brief list of power opamp: LM675, OPA569, L165 ... but be sure to check the dissipation of the device and provide correct cooling.
  8. #8
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,029
    I'd recommend a power MOSFET like the IRL540.
    Keeping the frequency above 20kHz is a good idea as you won't be able to hear it.
  9. #9
    chandu13 Newbie
    Join Date
    Aug 2006
    Posts
    98
    Default switching
    Thanks for the information
    Please can you provide interfacing circuit between the LPC2106 and Proportional valve?
    Shell I connect LPC2106 Port pin to the IRL540 with Rg, how to calculate the Rg value
    For PWM generation a I am using LPC2106 PWM Registers, it have in built PWM hardware
    PWMMR0=0x00003999; // base frequency register
    PWMMR4=0x00001CCC; // Duty cycle register
    PWMMR0=0x00003999; // 1KHz
    PWMMR0=0x00001CCC; // 500Hz
    PWMMR0=0x0000005C2; // 100Hz
    Clock frequency = 14.7MHz
    Regards
    chandu
  10. #10
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,698
    Blog Entries
    5
    The Philips NXP microcontrollers are not that popular in among the hobbyist market. I've not seen alot of code or even a users group for them. Why not use something more popular like PIC or AVR microcontrollers? Either can do simple PWM valve control.
    Bill
    Smart Kits build Smart People
  11. #11
    chandu13 Newbie
    Join Date
    Aug 2006
    Posts
    98
    Default Mosfet (irl540)
    Hay
    I have tested proportional solenoid with TIP122 & 1KHz frequency
    Across the load I am getting sufficient voltage but I am not getting the sufficient current to the solenoid
    So now I have to use power MOSFET (IRL540) & frequency above 20kHz
    How to interface LPC2106 with MOSFET (IRL540)
    please provide me information information
    Regards
    nari
  12. #12
    ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,807
    Blog Entries
    13
    Hay
    Regards
    nari
    hi Chandu,
    Why do you consider that the solenoid requires anywhere near a 20KHz frequency drive.?, that equates to a 25µSec half cycle pulse.
    Just changing the drive frequency is not PWM control.
    How accurately must you control the position of the valve.?
    IMO the inductance of the solenoid winding is having an effect upon the solenoid current at those higher frequencies.
    XL = 2 * Π * L * f
    EDIT:
    Does the prop valve have a spring return mechanism or does it require bi-directional PWM.?
  13. #13
    chandu13 Newbie
    Join Date
    Aug 2006
    Posts
    98
    Default valve position
    The proportional valve require unidirectional PWM pulses
    By varying the PWM duty cycle I have to control the valve position
    I am using Proportioning Solenoid Valve from
    Regards
    nari
  14. #14
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,807
    Blog Entries
    13
    Regards
    nari
    hi nari,
    I have looked at the pdf.
    What you need to do is control the pulse width as well as the frequency.
    Taking a very rough example:
    Assume the 100% operating speed from closed to open was say, 1 sec
    If you applied 24V, the 400mA would flow and the solenoid would fully open in 1 sec.
    If you now applied 24V for 0.5sec the valve would reach its 50% open point before the current was shut off,
    the valve would then start to close.
    If now you repeatedly applied a short pulse of 24V the valve would held at the 50% open point.
    By increasing or decreasing this 'holding' pulse width the valve could be held at any position.
    The graph on the pdf is just a guide, you will have to experiment with the PWM timing to get it just right.
    What I would do is to set up a variable freq 555 driving a variable delay monostable.
    The output of the mono would drive a power FET, which would power the valve.
    While varying the freq of the 555 and the delay of the mono, use a scope to get an indication of the range of the PWM.
    Once you have these values you could then program a PIC.
    Use the PIC's adc inputs and connect two pots, one for freq and the other for the PWM period. [use the on PIC PWM of course].
    Does this help.?
  15. #15
    chandu13 Newbie
    Join Date
    Aug 2006
    Posts
    98
    Hay
    I am facing hystersis problem while testing proportional solenoid valve.
    Solenoid valve rating is 0-24V & 400mA,I tested solenoid with variable DC power supply
    When ever I am applying 0-24 v the valve is opening but the valve is not closing at the same voltage
    Ex: Whenever I applied 16V(3.3) the valve is opened but it is closing at 5V(3.3)
    (OPENING)
    Volt(V) -> airflow (LPM)
    9 -> 0
    10 -> 0
    11 -> 0
    12 -> 0.5
    13 -> 1.7
    14 -> 2.8
    15 -> 3.1
    16 -> 3.3
    17 -> 3.4
    18 -> 3.4
    maximun flow
    (CLOSING)
    volt(V) -> flow(LPM)
    18 -> 3.4
    17 -> 3.4
    16 -> 3.3
    15 -> 3.3
    12 -> 3.3
    7 -> 3.3
    6 -> 3.3
    5 -> 1.6
    4 -> 0.8
    3 -> 0
    Regards
    chandu
+ Reply to Thread
Page 1 of 2
1 2 Last
  1. Switching AC
    By ScuzZ in forum General Electronics Chat
    Latest: 24th October 2007, 07:41 AM
  2. SPI Switching
    By rackley in forum Micro Controllers
    Latest: 18th November 2006, 03:36 PM
  3. Why switching ?
    By grandestlama in forum Electronic Projects Design/Ideas/Reviews
    Latest: 17th October 2004, 08:13 AM
  4. Switching PSU
    By Phasor in forum Electronic Projects Design/Ideas/Reviews
    Latest: 20th July 2003, 07:36 AM
  5. SCR switching 120 VAC
    By batman in forum Electronic Projects Design/Ideas/Reviews
    Latest: 2nd July 2003, 08:44 PM
Tags for this Thread
