Old 15th August 2008, 02:05 AM   (permalink)
Default Adc
Ad1con1
HI i am new in c programming,i have one doubt in the below coding.in this coding already set AD1CON2bits.BUFS=0(AD1CON2 = 0x041Fthen why we write code if (AD1CON2bits.BUFS==1),else if(AD1CON2bits.BUFS==0)
pls explain me, i am using P24FJ64GA002
void ADCInit()
AD1CON1 = 0x80E4; AD1CON2 = 0x041F;
AD1CON3 = 0x1102;
void _ISR _ADC1Interrupt(void)
unsigned int Temp;
Temp = ADC1BUF1;
Temp += ADC1BUF3;
Temp += ADC1BUF5;
Temp += ADC1BUF7;
Temp = Temp/4;
Adc_Vo += Temp;
Adc_Vo = Adc_Vo/2;
Temp = ADC1BUF9;
Temp += ADC1BUFB;
Temp += ADC1BUFD;
Temp += ADC1BUFF;
Temp = Temp/4;
Adc_Vo += Temp;
Adc_Vo = Adc_Vo/2;
sahanaashwin is offline
Old 15th August 2008, 03:00 PM   (permalink)
Originally Posted by sahanaashwin View Post
Ad1con1
pls explain me
The important thing to note here is the equality operator: ==, which differs from the assignment operator: =
The = is used to assign, as you have done with
AD1CON3 = 0x1102;
And this one == is used to test.
this line - if (AD1CON2bits.BUFS==1) - tests the bit BUFS in the AD1CON register, and if it is set (equal to 1,) executes everything between the { and } directly after that line.
IE: if the bit is set then
Temp = ADC1BUF1;
Temp += ADC1BUF3;
Temp += ADC1BUF5;
Temp += ADC1BUF7;
Temp = Temp/4;
Adc_Vo += Temp;
Adc_Vo = Adc_Vo/2;
will execute.
Or ELSE if the bit is clear (equal to 0) everything after that statement -
else if(AD1CON2bits.BUFS==0) -
and between the {} brackets will execute.
BeeBop is offline
Old 16th August 2008, 02:37 AM   (permalink)
I've messed that up a time or two =O
straight answer, har har."
Sceadwian is offline
Old 18th August 2008, 12:09 PM   (permalink)
thank you beebop
