| Yes this Main code builds fine Pommie here is the log file of it also what about the switch part of it is it possible if you hold the switch down for X number of seconds it will go to one routine but if you just hold it for lets say 1 second it runs a different routine ? I also see how you call the LED's now but im not sure what your getting at about changing the numbers since 0x55 in binary is 01010101 and in decimal its 85 ? and 10101010 doesn't correspond to anything under Multiplex unless you where just showing me how to do it without giving it away in that case I would just need to get the binary changed to Hexadeciaml and thats pretty simple Code: ---------------------------------------------------------------------- Debug build of project `C:\PIC12F509\Programs\LED_Cube_rev3 .disposable_mcp' started. Preprocessor symbol `__DEBUG' is defined. Sat Aug 16 21:04:46 2008 ---------------------------------------------------------------------- Clean: Deleting intermediary and output files. Clean: Done. Executing: "C:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe" /q /p12F509 "LED_Cube_rev3 .ASM" /l"LED_Cube_rev3 .lst" /e"LED_Cube_rev3 .err" /d__DEBUG=1 Loaded C:\PIC12F509\Programs\LED_Cube_rev3 .cod. ---------------------------------------------------------------------- Debug build of project `C:\PIC12F509\Programs\LED_Cube_rev3 .disposable_mcp' succeeded. Preprocessor symbol `__DEBUG' is defined. Sat Aug 16 21:04:47 2008 ---------------------------------------------------------------------- BUILD SUCCEEDED | |
| What does the code do? What it should do is light half the LEDs when the button is pressed. Changing the two numbers should light different LEDs. If this part is working then to make it change patterns is the next step. Mike. | |
| I can't really test it as I don't have the programmer to do so at the moment its at school and its locked for the summer so all keep this code as a backup can you explain how to get the LED's to light up without just randomly trying numbers and seeing what works and what doesn't ? is it using Hex ? not sure bc 0x55 doesn't correspond to any of the values of the Multiplex routine ? | |
| The 12 LEDs are lit by setting a bit in the variables LEDs and LEDs2 (only 4 bits in this one). So, 0x555 should light every odd numbered LED, 0xAAA would light the even LEDs, 0x001 would light just LED1, 0x007 would light LED1,2 & 3 etc. Without being able to test it on the hardware makes it very difficult to progress. Coding is best done in little steps, get one bit working and then move on to the next. Mike. | |
| Ok well all wait till I get the hardware then but I do still need to know how to do the timed switch if its possible ? allowing 2 different routines to be called depending on how long you hold the switch for Last edited by Darkstar64; 17th August 2008 at 04:10 AM. | |
| This is how I would write code so that a pattern is displayed when the switch is pressed and then a different pattern would be displayed 1 second later. Code: ;******** Main Code
start
movlw b'001000' ; Configure only GP3 as a input
tris GPIO
loop btfsc GPIO,3 ; Is switch 3 pressed?
goto TurnOn ;yes so go turn on LEDs
clrf LEDs ;turn off LEDs
clrf LEDs2
clrf DisplayCount ;reset counter
goto Display
TurnOn movfw DisplayCount
xorlw .10 ;reached 1 second
btfsc STATUS,Z
goto Pattern2 ;yes, go do pattern 2
incf DisplayCount,F ;increment counter - only if displaying pattern 1
;do pattern 1
movlw 0x55 ;setup pattern 1
movwf LEDs
movlw 0x05
movwf LEDs2
goto Display
Pattern2
movlw 0xAA ;setup pattern 2
movwf LEDs
movlw 0x0A
movwf LEDs2
Display
movlw .25 ;400uS * 25 = 10mS
movwf MultiCount
DisLoop call Multiplex ;this takes 400uS
decfsz MultiCount,F ;time up
goto DisLoop ;no, so do it again
goto loop
;****************** Delay Subroutine ( 10 ms ) Have fun. Mike. | |
| Pommie I ment like if you just hit the switch for a second then released it it would run a routine but if you held it for 5 seconds it would play the other routine and not the first one is this possible it will maby be a week before I can get any of the hardware at all so im still just trying to figure out the code for the switch but other then that everything is great including the multiplex routine and im kinda understanding how to turn each LED on and what not now I just have to find the 12F509's again in my house ahah by that time all have all the stuff I need and can start scewing with things to see what works what doesn't thanks Last edited by Darkstar64; 18th August 2008 at 02:04 AM. | |
| Help with the PIC12F509 | Darkstar64 | Micro Controllers | 13 | 31st July 2008 04:59 PM |
| is this the correct code for DS18s20?? | neels | Micro Controllers | 0 | 13th March 2005 05:13 AM |
| Am I correct? | Jef Patat | Electronic Projects Design/Ideas/Reviews | 2 | 8th February 2005 04:49 PM |
| Is this correct? | brodin | Micro Controllers | 7 | 14th March 2004 01:01 PM |
| basic code need help: cannot produce correct result | huanyong | Micro Controllers | 7 | 22nd October 2003 11:16 PM |
