Old 30th July 2008, 12:44 PM   #1
Default first PIC assembly program
Hi all! I'm still on my quest to write simultaneously (or either) my first PIC assembly program, and a PIC program that produces an NTSC video signal. I found this post elsewhere on the internet: http://www.rohitab.com/discuss/lofiv...hp/t15740.html
It seems to me that it's a little more straight forward than the Rickard's website explanation (which I can't seem to find online anymore, anyway), at least in terms of being able to understand the code. I think I'm almost to the point of being able to understand it, but I still have a few questions.
1. How would I go about modifying the header to use a 16F88 and internal oscillator? I think I can get 4MHz as an internal oscillator option on a 16F88, can't I?
2. Generally, what does "org" do? Specifically, what do these lines in the program do:
org 0x00
goto Main
3. Is the "Main" section of the code outdated/redundant/unnecessarily wordy? It seems to me I was called out for something along this line before, because some part of this is now articulated in the include file? At the end of the day, I believe this part of the code is just switching banks, setting PORTA as an input, and PORTB as an output, and then switching back banks again, correct? What's the best way to do that if this isn't it?
4. I don't really understand what's happening with the goto statements. What's the syntax of "goto" as it relates to this code? I think I remember reading up on what happens, but I'm either confused or have forgotten, and I'm unclear on the use of the $ symbol in this code.
5. I also don't understand what's happening in the "Delay" subroutine, and the use of the _D variable.
I just wanted to add that I think I understand what needs to happen electronically to produce an NTSC signal at this point. I'm just having trouble following the code, and getting to the point where I understand enough of it to comfortably code in assembly. I probably should clarify that the poster of this code did so with the intention of it being used to create a PAL signal, but as it doesn't use any vertical sync (just a continuous stream of horizontal patterns), and with the leeway that, as far as I know, modern NTSC televisions will permit, this shouldn't be a problem. I hope.
list p=16f84A
#include "P16f84.inc"
__config _CP_OFF & _WDT_OFF & _PWRTE_ON & _XT_OSC
w equ 0
f equ 1
SYNC equ h'00'
BLACK equ b'00010000'
GREY equ b'00100000'
WHITE equ b'00110000'
_D equ h'12'
org 0x00
goto Main
org 0x04
goto Main
_2NOP macro
    nop
    nop
    endm
_6NOP    macro
    nop
    nop
    nop
    nop
    nop
    nop
    endm
Main
    bsf STATUS,5
    movlw h'00'
    movwf TRISB
    movlw h'ff'
    movwf TRISA
    bcf STATUS,5
Line
    movlw SYNC                                      /G16
    movwf PORTB    ;2µs unused                      /G17
    _2NOP        ;Start 4µs SYNC                  S2
    movlw BLACK                                     S3
    movwf PORTB                                     S4
    _6NOP        ;Start 8µs BlackLevel                B6
    movlw WHITE                                     B7
    movwf PORTB                                     B8
    btfsc PORTA,0     ;Is the button pushed?            W1/2
    goto $+3        ;yes jump 3 lines forward    W3
    movlw h'07'        ;no                        W3
    call Delay        ;25µs white line           W28
    movlw BLACK                                     W4/29
    movwf PORTB                                     W5/30
    btfss PORTA,0    ;is the button pushed?              B1
    goto $+3        ;no jump 3 lines forward       B3
    movlw h'07'        ;yes                       B3
    call Delay                                       B28
    movlw GREY                                   B4/29
    movwf PORTB                                     B5/30
    _6NOP                                               G6
    _6NOP                                              G12
    Nop                                            G13
    goto Line                                      G15
Delay
    movwf _D
    decfsz _D
    goto $-1
    return
end
Hank Fletcher is offline
Old 30th July 2008, 01:27 PM   #2
Yes 4 and 8MHz internal are available.
org 0x00
goto Main
It instructs the assembler to start the coding, from program counter address 0000
The main can be any label/name you choose.
The goto tells the program to load the goto destination address into the program counter and then go there.
The -D is just a register label, in this context its used as counter register for the delay routine.
list p=16f84A
w equ 0
f equ 1
SYNC equ h'00'
_D equ h'12'
org 0x00
goto Main
org 0x04
goto Main
_2NOP macro
    nop
    nop
    endm
_6NOP    macro
    nop
    nop
    nop
    nop
    nop
    nop
    endm
Main
    bsf STATUS,5
    movlw h'00'
    movwf TRISB
    movlw h'ff'
    movwf TRISA
    bcf STATUS,5
Line
    movlw SYNC                                      /G16
    movlw BLACK                                     S3
    movwf PORTB                                     S4
    movlw WHITE                                     B7
    movwf PORTB                                     B8
    movlw h'07'        ;no                        W3
    movlw BLACK                                     W4/29
    movwf PORTB                                     W5/30
    movlw h'07'        ;yes                       B3
    call Delay                                       B28
    movlw GREY                                   B4/29
    movwf PORTB                                     B5/30
    _6NOP                                               G6
    _6NOP                                              G12
    Nop                                            G13
    goto Line                                      G15
Delay
    movwf _D
    decfsz _D
    goto $-1
    return
end
The $ is the current value of the Program counter.
Does this help.?
EDIT: image added for freq select
ericgibbs is offline
Old 30th July 2008, 01:36 PM   #3
hi Hank,
If you are porting this program to the 16F88, remember the 'free registers' start address at 0x20.
BTW: I would check the stabilty of the internal RC osc, when using for video timing applications.
Old 30th July 2008, 10:19 PM   #4
Originally Posted by ericgibbs View Post
hi Hank,
..., when using for video timing applications.
Wow, I'm impressed. Most folks start out blinking a LED.
Creationists have a world of evidence
AllVol is offline
Old 31st August 2008, 03:24 AM   #5
Have you figured out if the internal Osc will work for video. I was told the ceramic osc's were not.
BCHS/3v0's Tutorials
3v0 is offline
Old 31st August 2008, 11:51 AM   #6
A ceramic resonator is FAR better than the internal RC oscillator, a ceramic one would probably work fine. But even with the internal oscillator it should work anyway, the TV syncs to the incoming signal, so slight variations should make no difference.
assembly, pic, program
[Help] Assembly program for 8052 (ADC serial in) xela Micro Controllers 5 26th March 2007 11:43 AM
First Program in assembly, And Programmer Inchworm. Ayne Micro Controllers 10 9th March 2007 08:27 PM
Assembly Language - My program keeps on restarting avinsinanan Micro Controllers 3 15th April 2005 05:23 AM
Tough assembly program for the PIC16F84 asmpic Micro Controllers 34 3rd December 2004 07:50 PM
Need a program in Assembly that reads PWM avinsinanan Micro Controllers 1 19th August 2003 10:43 PM
