I work in foss world, that's my b&b ... I push for linux app's where ever I can .. and to be honest, in the "elco" world, that just do not cut it ... as much as "elco" engineers share code, share schematics, ideas ... the developers of the "elco" tools are "crazy darn skico" .. I offered to one of the "usb oscilloscope developers" *FREE* help to port the driver and application to linux, after 4 months I got answer that they are not interested in making drivers for linux for their device ?!?!?! I asked nothing in return, I already purchased the device ... So, when we look truth in the eye's, there's just too much hassle around it that is not related to development itself (administration, politics, birocracy) that I do not think we can expect foss pic C compiler soon anyhow .. I posted a pretty useless post now but feel much better afterwards | ||
| After installing the Hi-Tech compiler MPLAB no longer knows about most of the other compilers I have installed. Maybe somthing when wrong with my install but I did not see any problems. EDIT: All the compilers show up in the "Set Language Tool Location". With either the 18F1320 or 18F1330 device selected in "Select Language ToolSuite" I only see "Hi-TECH Universial, Microchip C30, and Microchip PIC32 Compiler".
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 22nd July 2008 at 12:40 PM. Reason: update | |
| Yeah I installed it yesterday as well and see the same behaviour. Looks like they overwrite MPLAB config files rather than appending/updating them. Good thing is that I was able to compile a led blink C program for PIC16F628 with it. I am yet to burn a PIC with it and see if it really works
__________________ Its not the Practice that makes a man perfect. Its the Man who makes the practice perfect ----- Pradeep K. Shima ----- | |
| Hey guys, how do you install it (Hi-Tech) into MPLAB? | |
| I didnt do anything special. Just install the Hi-Tech thing by running its installer. No manual intergration required. Just be carefull that Hi-Tech seems to monopolise things by removing all other compiles from the list of toolsuites in MPLAB.
| I did not do anything special to install it. Just ran the installer whatever it was. I am going to attempt reinstalling MPLAB 8.14. (It is what I was using).
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 22nd July 2008 at 01:18 PM. | |
| I seem to remember an option box that needed ticking in order to integrate into MPLAB, it was a while ago when I installed it and so I could be mistaken. Mike. | |
| I know that was the case for BoostC but I do not recall if there was one for Hi-Tech.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | |
| I am all set now I can compile C programs for pic16F628A using Hi-Tech and for PIC18F1320 using C18. All this from within MPLAB. I am finally getting the feel of microcontrolers the way I wanted it.
I am mostly dead in the water and looking at removing MPLAB and installing from scratch. Unless the info about compilers is stored in registery and then a rollback might fix it.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 22nd July 2008 at 06:46 PM. | ||
| I was running MPLAB 7.6 so I had to upgrade anyways. So when I started the install of the latest version 8.10, it asked me to close everything else and to uninstall all prior versions. I did. After the install, it automatically ran the picc installer and everything was fixed Now I can see all toolsuites in MPLAB.
| MPLAB is fixed The problem may have been due to several installed versions of MPLAB. Microchip says we should only have one, up to the point where I installed the Hi-Tech compiler it was not a problem. I uninstalled all versions and the problem was still there after a reinstall of 8.14. I uninstalled, rolled back the system to just prior to the Hi-Tech install and then installed MPLAB again. That seems to have fixed it. pkshima: thanks for posting about what you did to fix yours. I was enough to get me moving on this. I would not count this a much of a ding. It may not have happened if I had removed the old version of MPLAB when I should have.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 22nd July 2008 at 09:18 PM. | |
| Thanks for ingo' guys. I found I had several MPLAB installs listed in my Add/Remove Programs list too so I'm going to do my long overdue upgrade from MPLAB 8.01 to interim 8.14. | |
| MPLAB 8.14 now installed. The Hi-Tech toolsuite still doesn't show up in the pick list for a 16F628/A device. I downloaded Hi-Tech PICC-Lite 960PL2 and installed it on my hard drive last week. Is there some other step I need to do for MPLAB to recognize it? Also, the User Manual pdf included in 960PL2 is dated February 2008 and the 16F628/A isn't listed in the supported device list. Is there a more up to date list of supported devices? Mike Last edited by Mike, K8LH; 22nd July 2008 at 10:54 PM. | |
| | (permalink) | ||
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 22nd July 2008 at 11:02 PM. | |||
| finally getting a PIC | davidbball13 | Micro Controllers | 45 | 23rd June 2008 03:04 AM |
| I finally got a scope! Help! | bigal_scorpio | General Electronics Chat | 9 | 26th May 2008 10:30 PM |
| Atmel AVR free compiler and support free forum | mramos1 | Micro Controllers | 3 | 24th October 2005 09:00 AM |
| its finally here! (I just need to tell somebody) | Steve P | Micro Controllers | 19 | 2nd September 2005 07:05 PM |
| free basic compiler | Neiwiertz | Micro Controllers | 3 | 24th December 2003 04:34 PM |
