Old 18th July 2008, 12:25 AM   #1
Angry BoostC Flaw?
I wrote this simple code
#include <system.h>
#pragma DATA	_CONFIG1H, _INTIO1_OSC_1H
#pragma DATA	_CONFIG2L, _BOR_OFF_2L
#pragma DATA	_CONFIG2H, _WDT_OFF_2H
#pragma DATA	_CONFIG4L, _LVP_OFF_4L
#pragma	CLOCK_FREQ 8000000
void main(void)
    set_bit( osccon, IRCF2 );           //8 MHz
    set_bit( osccon, IRCF1);
    set_bit( osccon, IRCF0 );
	trisb=0;
    trisa=0;
    porta=0;
    portb=0;
    porta.1=1;
    delay_s(2);
    porta.2=1;
	while(1){
Yet it doesnt work right. Im worried it might give me a issue later on. What it does it light led 1 on RA1 then led 2 on RA2 but once it lights led 2 LED 1 turns off.
How come?
AtomSoft is offline
Old 18th July 2008, 01:22 AM   #2
You probably meant to use _INTIO2_OSC_1H. Using INTIO1 loses you the RA6 pin as a usually useless clock output.
That's fine, but these can also be done with either
    osccon,IRCF0=1;
    osccon,IRCF1=1;
    osccon,IRCF2=1;
or
    osccon=0x72;
These can be simplified if you want
	trisa=trisb=0;
        porta=portb=0;
And this can be simplified too
	while(1);
How come?
Not sure. Is this on Junebug? Show me your circuit.
Probably nothing to do with it, but your "porta.1=1" and such should be "lata.1=1". Use the latch/shadow registers instead of the ports and you'll avoid weird problems later.
futz is offline
Old 18th July 2008, 01:37 AM   #3
wow wierd i did this:
#include <system.h>
#pragma DATA	_CONFIG1H, _INTIO2_OSC_1H
void main(void)
    osccon=0x72;           //8 MHz
	trisb=trisa=0;
    porta=portb=0;
    lata.1=1;
    delay_s(1);
    lata.2=1;
	while(1){
works fine now...
AtomSoft is offline
Old 18th July 2008, 01:41 AM   #4
works fine now...
So it's happy with lata.1/2, but not with porta.1/2? How strange! Oh well, you should be using the LAT's anyway on 18F's.
futz is offline
Old 18th July 2008, 03:40 AM   #5
yeah its pretty wierd but as long as it works. ill be sure to use lata for pic18F from now on. by the way im away from home and am writing this on a psp.
AtomSoft is offline
Old 18th July 2008, 04:15 AM   #6
Are you using current limiting resistors on the LEDs? If not, it is possible that the Read/Modify/Write instruction won't work properly using the porta register. Using lata is the preferred method anyway. Which PIC are you using? Some pins are TTL level and others are Schmitt Trigger level pins.
kchriste is online now
Old 18th July 2008, 11:12 AM   #7
it was happening on 2 PICs. My Junebug(18F1320) and a 18F248. But all is well and im happy lol
edit: also i due have 2 resistors on it. (100ohm)
AtomSoft is offline
Old 19th July 2008, 04:32 AM   #8
If you want, measure the voltage on the pins driving the LEDs when the LEDs are on. If it is equal or less than 2V, then that was the problem but with the 100Ω resistors it should be above 2V according to the spec sheet.
boostc, flaw
BoostC Charlieplexed PWM 32 Mike, K8LH Micro Controllers 140 27th March 2009 11:19 AM
BoostC 12F683 Serial I/O Example Mike, K8LH Micro Controllers 5 2nd October 2008 07:21 PM
BoostC USART 18F AtomSoft Micro Controllers 9 29th June 2008 05:02 PM
BoostC question.. AddressOf Mike, K8LH Micro Controllers 8 25th June 2008 12:20 AM
math.h and lib for BoostC? futz Micro Controllers 3 31st March 2008 06:29 AM
