Hello Gurus! I have build a JDM programmer, and I am able to program 16F84 & 628 chips without problems. But I could not program 877A. On the JDM programmer site, it tells JDM can program 877(A?), but cannot use the default schematic - I have to build an adapter. http://www.jdm.homepage.dk/newpic.htm It does not give detail about how to build the adapter (i.e. pin-mapping) for 877A, so I try to use its In-Circuit Serial Programig (ICSP) function. http://www.jdm.homepage.dk/icsp.htm Following the instruction, I linked the 5 pins (MCLR,Vdd,Vss,RB6,RB7) to the 877A, but it didn't work. I got "Verify failed ar address 0x00000", normaly it means the write was unsuccessful. I now have the following questions - 1) Have you programed 877A using JDM and/or ICSP? How do you do it? 2) How (where) should I connect the other pins of 877A (i.e. ground, 5V, clock, etc)? I ONLY connect these 5 pins to the programmer, other pins is not connected to anywhere, but I suspect I could be wrong. 3) Where can I find information about how to build JDM/16F877A adapter? Thank you very much!!! Michael | |
| | #2 | |
16F877 is EEPROM, 16F877A is Flash | ||
Exo, I mean no disrespect, but FLASH is another word for EEPROM
nope it isn't Eeprom allows writing to a single word. Flash requires read/write in Blocks (i believe pics do it in blocks of 4 words) (http://www.webopedia.com/TERM/F/flash_memory.html) Anyway 16F877 and 16F877A require diffirent programming routine. You can not program a 16F877A with software that only supports 16F877 | |
I used icprog on windows 2000. As I said, it can program 16F84A, which I assume to be similar to 16F877A regarding to programming algorithm/method. icprog says it can program 877A, but I am not sure about JDM the hardware. Also I wonder how should I connect the all 40 pins of 16F877A when program with JDM. Regards. Michael | |
| | #6 |
Ok, i phrased it wrong, basically they say that flash is eeprom (which if what i meant) but yeah, regardless of names, if programming technique is different then it's a no go | |
| | #7 |
download the most recent version of IC-prog. It should support it. (Well mine does) and you also need to add a capacitor of 100nf across VDD and VSS. and also a 4.7k resistor on RB3/PGM to the ground rail. This should work fine.
__________________ www.winpicprog.co.uk - Great PIC language tutorials. | |
| | #8 | |
As the author of WinPicProg I've spent a fair bit of time sorting this all out, interestingly enough icprog includes the 16 bit version of my disassembler, presumably he based icprog on my old 16 bit code which I released?. MicroChip (along with other manufacturers) have confused the issue greatly by calling the EEPROM chips FLASH - purely for advertising purposes. | ||
