+ Reply to Thread
Page 2 of 3
First 1 2 3 Last
Results 16 to 30 of 38
Thread: LED Sign Board 30X7 - PIC16F628A
  1. #16
    Mike, K8LH Excellent Mike, K8LH Excellent Mike, K8LH Excellent Mike, K8LH Excellent Mike, K8LH Excellent Mike, K8LH Excellent Mike, K8LH Excellent
    Join Date
    Jan 2005
    Location
    Michigan, USA
    Posts
    2,522
    I would prefer to "scan" the rows to increase duty cycle and reduce "peak" current requirements for full brightness.
    You could easily modify and expand your 7x30 circuit using this method;
    (1) remove the current limiting resistors from the row pins.
    (2) install row driver transistors. you'll only be driving one row at a time.
    (3) use 74HC164 or 74HC595 or similar 8 bit shift registers for the columns.
    (4) drive the ULN2803 sinking drivers from the shift register outputs.
    (5) install current limiting resistors on the ULN2803 outputs.
    Actually, you'll probably want to use row driver transistors for every 10 or so columns unless you install some very "big" transistors (grin).
    I would actually use 8 bit serial-to-parallel sinking driver ICs for the columns instead of the dual IC combo' but they're expensive. For the dual IC combo' I guess I would choose the 74HC595 over the 74HC164 because the '595 has a latch which would allow us to take our time loading 100 bits of data into the shift registers without messing up the display. The '595 also has an output enable pin which could be driven by a PWM signal to control display brightness.
    Regards, Mike
  2. #17
    Join Date
    Jan 2005
    Location
    Michigan, USA
    Posts
    2,522
    With the very good brightness you're getting on your 7x30 display with only a 1/30th duty cycle, I am thinking that you might actually have several different options for an expanded 7x100 version. Perhaps you don't really need to use 13 74HC595's and 13 ULN2803's for a 1/7th duty cycle 7x100 display.
    Let me think about this and get back to you Sir.
    Mike
  3. #18
    Gayan Soyza Excellent Gayan Soyza Excellent Gayan Soyza Excellent Gayan Soyza Excellent Gayan Soyza Excellent Gayan Soyza Excellent
    Join Date
    Oct 2006
    Location
    Colombo
    Posts
    1,664
    Blog Entries
    1
    Master are you there!
    Ah yes that 74HC164 is one of my favorites & I have done some few boards using that.I have attached one of my PCB layout done in past.
    I'd like to do a row scan to a large column displays.
    Thanks for your information.
    A bit off topic what you doing these days sir?
  4. #19
    Magen Newbie
    Join Date
    May 2008
    Location
    Johannesburg,South Africa
    Posts
    48
    Hi Gayan,
    That's a nice display. What Led's did you use? I am trying to build a sign just like it.
  5. #20
    Join Date
    Oct 2006
    Location
    Colombo
    Posts
    1,664
    Blog Entries
    1
    Quote Originally Posted by Magen View Post
    Hi Gayan,
    It’s a type of super bright LED designed for signboards.
    Forward current 20mA (operating below that with the same brightness)
    Forward voltage 1.9V
    Viewing angle below 30 d.
    Actually there were no many that type of LEDs in my place so I have to shift to a ready made MATRIX.
  6. #21
    Magen Newbie
    Join Date
    May 2008
    Location
    Posts
    48
    Hi Gayan,
    Where did you purchase those leds from? Do you have a part number or something for it? Or even a link to a website?
  7. #22
    Bolaji Newbie
    Join Date
    Oct 2008
    Posts
    2
    Quote Originally Posted by Gayan Soyza View Post
    Gayan,
    I have interest in building LED Sign Board that is scrolling led display(Like the one you posted 9th July 2008), has a project kindly help me with materials to use and how I can go about it. What I want the Sign board to display the Message "WELCOME TO SCHOOL + arrow". Gayan, I will very happy if you can assist. Awaiting your replay, Thanks.
    Regards
    Bolaji
  8. #23
    Join Date
    Oct 2006
    Location
    Colombo
    Posts
    1,664
    Blog Entries
    1
    Quote Originally Posted by Bolaji View Post
    Gayan,
    Regards
    Bolaji
    If you have experience with PICs I can give a hex file with a message "WELCOME TO SCHOOL + arrow"
  9. #24
    Bolaji Newbie
    Join Date
    Oct 2008
    Posts
    2
    Gayan,
    I do not have experience with PICs.
    thanks
    Bolaji
  10. #25
    F877 Newbie
    Join Date
    May 2009
    Posts
    3
    Can you provide a schematic?
  11. #26
    F877 Newbie
    Join Date
    May 2009
    Posts
    3
    thanks
  12. #27
    F877 Newbie
    Join Date
    May 2009
    Posts
    3
    thanks site
  13. #28
    ameryknu Newbie
    Join Date
    May 2009
    Posts
    1
    can you provide us some schematics...i'm interrested about how to made a signboard...thanks
  14. #29
    bernal_john Newbie
    Join Date
    Sep 2009
    Posts
    1
    Default i need help
    is there anyone who can help me with my project? it's actually a 30x7 LED array display. and im using discrete LED's. and im just using a microcontroller which has 16 outputs only... what IC will i use in order to drive or to aid my array display???
  15. #30
    deansmith Newbie
    Join Date
    Jan 2007
    Location
    English-live in Germany
    Posts
    38
    Gayan Soyza, can you post a schematic and hex or asm file for pic16f628 please please pretty please. Or tell me where i can find a scrolling LED tutorial useing a 16f628 and .asm
+ Reply to Thread
Page 2 of 3
First 1 2 3 Last
  1. LED house sign
    By sammy004 in forum General Electronics Chat
    Latest: 19th April 2008, 05:31 AM
  2. 5X7 Dot matrix Scrolling sign
    By robomanjosh in forum Electronic Projects Design/Ideas/Reviews
    Latest: 25th September 2006, 09:43 PM
  3. Bright Lamps for Sign?
    By arrow in forum General Electronics Chat
    Latest: 20th February 2006, 01:34 PM
  4. sign maker
    By moody07747 in forum Chit-Chat
    Latest: 15th August 2005, 06:17 AM
  5. scrolling LED sign
    By computeruser in forum General Electronics Chat
    Latest: 8th September 2004, 12:43 PM
Tags for this Thread
