Old 28th June 2008, 03:14 PM   #1
Default BoostC USART 18F
Ok im having some trouble receiving from Hyper Terminal to my PIC18F1320.
Im using BoostC to program/
I can send data out with no problem... Here is my receive code:
void RxRecv(char &MyTmp)
    while(!pir1.RCIF);
        MyTmp = rcreg;
        Rs_Send(rcreg);
and this is how im calling it
    while(1)
        char Tmp2 = 0x00;
        RxRecv(Tmp2);
Now for some reason when i type a key in hyper terminal it wont work. But i have the same code in ASM and it works fine on same chip. Any thoughts?
AtomSoft is offline
Old 28th June 2008, 03:43 PM   #2
Arrow
The argument of the function RxRecv() looks wrong to me.
Does this work?
unsigned char MyTmp;
unsigned char RxRecv(){
    while(!PIR1.RCIF);
    return RCREG;
while(1){
    MyTmp = RxRecv();
    Rs_Send(MyTmp);
eng1 is offline
Old 28th June 2008, 04:04 PM   #3
    while(!pir1.RCIF);
        MyTmp = rcreg;
        Rs_Send(rcreg);
Try changing it to void RxRecv(char *MyTmp) and your calling code to RxRecv(&Tmp2);
The (char *) tells the compiler to expect a pointer with the address of a char variable and &Tmp2 passes the address of the variable.
Pommie is online now
Old 28th June 2008, 06:11 PM   #4
The actual issue is i cant seem to get passed the (bold):
    while(!pir1.RCIF);  //Not correctly checking Flag even with
                        //a breakpoint i cant skip this
        *MyTmp = rcreg;
        Rs_Send(rcreg);
AtomSoft is offline
Old 28th June 2008, 06:44 PM   #5
Did you set bit CREN, that enables the reception?
eng1 is offline
Old 28th June 2008, 06:52 PM   #6
yes here is my full code: (still nothing)
#include <p1320.h>
#pragma	CLOCK_FREQ 8000000
void Rs_Init()
    //RS Init.
    trisb = 0b00010010;
    portb = 0x00;
    spbrg = 0x0C;
    txsta.BRGH = 0;
    baudctl.BRG16 = 0;
    txsta.SYNC = 0;
    rcsta.SPEN = 1;
    rcsta.CREN = 1;
    txsta.TXEN = 1;
void Rs_Send (char tx_char)
    while(!pir1.TXIF);
    txreg = tx_char;
void puts(char *source)
	while (*source != 0) // wait until tx register is empty
	    Rs_Send(*source++);
        Rs_Send(0x0d);
        Rs_Send(0x0a);
        *MyTmp = rcreg;
        Rs_Send(rcreg);
void main()
    //PIC Init.
    osccon.IRCF2 = 1; // 8Mhz Clock
    osccon.IRCF1 = 1;
    osccon.IRCF0 = 1;
    Rs_Init();
    puts("Hello, world\r\n");
    while(1)
        char Tmp2 = 0x00;
        RxRecv(&Tmp2);
AtomSoft is offline
Old 28th June 2008, 07:57 PM   #7
You did not configured the A/D channels, did you? Try adding this line at the begining of the main function:
ADCON1 = 0xFF;
eng1 is offline
Old 28th June 2008, 08:43 PM   #8
Does this work?
char Tmp2 = 0x00;
while (1) {
      if (pir1.RCIF) {
         Tmp2 = rcreg;
         Rs_Send(Tmp2);
      } // end if
} // end while
Why not use an interrupt?
BeeBop is offline
Old 28th June 2008, 09:52 PM   #9
ADCON1 = 0xFF;
Thanks a bunch! this works now. I should have seen it in my asm code but i guess i was going to fast! thanks a lot.
AtomSoft is offline
Old 29th June 2008, 05:02 PM   #10
Full Code Everything WORKING ! 100%
AtomSoft is offline
18f, boostc, usart
BoostC Charlieplexed PWM 32 Mike, K8LH Micro Controllers 140 27th March 2009 11:19 AM
BoostC question.. AddressOf Mike, K8LH Micro Controllers 8 25th June 2008 12:20 AM
LCD degree symbol with sprintf (BoostC) futz Micro Controllers 29 5th June 2008 05:19 AM
math.h and lib for BoostC? futz Micro Controllers 3 31st March 2008 06:29 AM
PIC USART: Help Please mortuzahasan Micro Controllers 2 11th February 2007 07:28 PM
