Old 27th June 2008, 11:54 AM   (permalink)
Default baud rate
hi
i am trying to write a program to send data to PC through air using LEDs and
photodiodes . i am using 4800 baud rate to comunicate .thus for approx 208microsec the led should toggle to send one bit. i have wriiten a program to toggle the led ,wait for 208 microsec and then toggle again.
BUT THATS NOT WORKING
data is displayed but not the one i try to send
Can anybody tell me how to calcute the delay time between two toggles for 4800 baud rate
aamirkhan is offline
Old 27th June 2008, 12:19 PM   (permalink)
If you connect the LED to the USART port of a PIC, and set-up the port correctly you should not have to worry about usec etc time. Don't know how well a photodiode will work at that speed though.
Boomslang is offline
Old 27th June 2008, 12:50 PM   (permalink)
i am not using UART its already occupied .I have to built another using program.
Old 27th June 2008, 01:05 PM   (permalink)
If I understand correctly, you want to write the program for a 'software' UART.
Look at Nigels tutorials link, bottom of this post.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 27th June 2008, 01:10 PM   (permalink)
Use a wire connection first to debug the 232, and once you have it working use the LED, so that you can address one problem at a time. Never tried 232 in software so can't help you on that.
edit to add: If you use the LED/photo setup on your existing uart connection, does it work?
but i am using AT89S52 not PIC
Old 27th June 2008, 01:13 PM   (permalink)
The same principles apply - basically that you usually require some kind of coding for IR or radio use, neither of which output the same width pulses you supply them.
Nigel Goodwin is online now
FSK Baud rate khgsm2007 General Electronics Chat 7 10th May 2008 12:41 PM
PIC 18f1220 EUSART Baud Rate Cache Problem wklose99 Micro Controllers 7 16th April 2008 10:37 PM
Baud rate transmission problem Spectacular Butter General Electronics Chat 18 24th February 2005 09:30 AM
Baud rate and frequency Spectacular Butter General Electronics Chat 5 6th December 2004 07:25 PM
Setting Baud Rate for Modem connected to 89c52 ????? Yatin Electronic Projects Design/Ideas/Reviews 1 13th September 2004 10:11 AM
