Old 28th June 2008, 10:44 PM   #46
Replace this part of main() with this new version. Should work better on side by side displays:
	reset();
	trail[0]=10;trail[1]=8;trail[2]=5;trail[3]=2;trail[4]=1;
	while(1){
		for(x=0;x<10;x++){
			reset();
			led[x]=31;
			led[(x-9)+19]=31;
			for(y=0;y<5;y++){
				if((x-(y+1))>-1)
					led[x-(y+1)]=trail[y];
				if(((x-9)+19)-(y+1)>9)
					led[((x-9)+19)-(y+1)]=trail[y];
			delay_ms(30);
		for(x=9;x>0;x--){
			reset();
			led[x]=31;
			led[(x-9)+19]=31;
			for(y=0;y<5;y++){
				if((x+(y+1))<10)
					led[x+(y+1)]=trail[y];
				if(((x-9)+19)+(y+1)<20)
					led[((x-9)+19)+(y+1)]=trail[y];
			delay_ms(30);
futz is offline
Old 29th June 2008, 01:47 AM   #47
Here's my version of the schematic. If you want to use GP3 as an input and still be able to use ICSP then you'll have to add a third switch (or some other means of isolation) to switch between VPP use and input use.
futz is offline
Old 29th June 2008, 03:55 AM   #48
Whether the connections to R6 and R7 be changed to after the programming switch? It would help in-situ programming, not to have load on the chip pins. The schematic after suggested mod is attached.
By the way I saw another youtube video . i felt it excellent. and link is here
YouTube - 12F683 Bluebox
Regards,
Sarma.
mvs sarma is online now
Old 29th June 2008, 04:09 AM   #49
Yes, I thought of that. Already had it wired the other way though, and didn't feel like changing it. Anyway, it works perfect as is, without that change. I'm lazily soldering one together. Guess I'll make that change on the soldered one.
By the way I saw another u-tube video . i felt it excellent. and link is here
Ya, I watched that. Nice project.
futz is offline
Old 29th June 2008, 05:27 AM   #50
Here it is, Mr. Sarma. Added the third switch as well, so that one last input pin can be used.
futz is offline
Old 29th June 2008, 08:53 AM   #51
Attachment 20072
Nice Futz, ultimate as all pins are now free for use. Great job.
On the trailing lamps project, please imagine the lamps physically mounted in a curve shape and let the trail display . , hope it would simulate a snake motion. ofcourse we may have to mask the board by say a green foil or perspex.
Regards,
Sarma.
Old 29th June 2008, 04:32 PM   #52
    reset();
    while(1){
        for(x=0;x<10;x++){
            reset();
            led[x]=31;
            led[(x-9)+19]=31;
            for(y=0;y<5;y++){
                if((x-(y+1))>-1)
            delay_ms(30);
        for(x=9;x>0;x--){
            reset();
            led[x]=31;
            led[(x-9)+19]=31;
            for(y=0;y<5;y++){
                if((x+(y+1))<10)
            delay_ms(30);
Futz,
You've come up with a couple extremely nice "Cylon Eye" examples. Thank you.
I tried to come up with my own version late last night and I'm still stuck. It's much harder than I thought it would be when I casually suggested someone "throw something together" (grin).
Mike
Mike, K8LH is offline
Old 30th June 2008, 12:13 AM   #53
Mike. I have one little question. How are your LEDs laid out?
00-19
01-18
02-17
03-16
04-15
05-14
06-13
07-12
08-11
09-10
or
00-10
01-11
02-12
03-13
04-14
05-15
06-16
07-17
08-18
09-19
I lean toward the first layout.
futz is offline
Old 30th June 2008, 12:39 AM   #54
That board was originally a Serial LED Bar/Dot Controller so led 00 is bottom left, 09 is top left, 10 is bottom right, and 19 is top right.
BTW, I completely understand both of your Cylon Eye examples. I was just trying to see if I could come up with something as good or better. Talk about a humbling experience (grin)...
Old 30th June 2008, 06:43 AM   #55
Originally Posted by Mike, K8LH View Post
Hi Gayan,
I'm not sure what you mean by "hack my design".
Attached is picture of bottom of board. It contains one surface mount PNP row driver transistor on GP0 (an experiment to increase peak current from 20 ma to around 50 ma).
Mike
Thanks for that Mike.Because I like to know what methods other guys use when they are soldering..........
ahhhhhhhhhhh
This guy has made a UV meter from PIC16F628.Unfortunately I couldn't find any schematic from it.
It also has a fade trail.
YouTube - PIC16F628 64 led bar
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline
Old 30th June 2008, 07:17 AM   #56
I finished my permanent Mike-K8LH blinky thing. Works fine and now I can have my breadboard back. Here's a couple pics:
futz is offline
Old 30th June 2008, 10:16 AM   #57
Oh! what an wiring effort Futz... looks Good and thanks for the photos.
Regards,
Sarma.
Old 30th June 2008, 11:23 AM   #58
Futz,
Your board looks excellent...
Those PCB mounted slide switches look great. May I ask about Manufacturer, Part Number, Source, please?
You probably could have done away with the switch on GP3. I just added a push button "mode" switch onto my board at GP3 with a pull-up resistor. You can also potentially use GP3 for bit-banged serial receive.
Mike
Old 30th June 2008, 03:23 PM   #59
They are Digikey part# EG1903-ND. That's a Canadian link. For US link, click here.
Those switches work great on breadboards too.
True. Could rig a single tact switch to control all three lines. Just hold down to program.
futz is offline
Old 30th June 2008, 04:18 PM   #60
I don't understand.
You wouldn't need a slide switch at all for GP3 because that would be connected to a normally open push button switch.
How would you connect a single push button switch to disconnect GP0/ICSPDAT and GP1/ICSPCLK from the LED circuitry when you push it and hold it down?
boostc, charlieplexed, pwm
BoostC question.. AddressOf Mike, K8LH Micro Controllers 8 25th June 2008 12:20 AM
LCD degree symbol with sprintf (BoostC) futz Micro Controllers 29 5th June 2008 05:19 AM
math.h and lib for BoostC? futz Micro Controllers 3 31st March 2008 06:29 AM
Charlieplexed code segment for the Cricket Thermostat William At MyBlueRoom Micro Controllers 2 14th March 2006 05:12 PM
My PIC Projects Site NEW (includes 2 Charlieplexed Display) William At MyBlueRoom Electronic Projects Design/Ideas/Reviews 0 28th February 2006 02:31 PM
