Old 26th June 2008, 12:20 PM   #16
Refresh Rate = 1 / (column1period + column2period + column3period + column4period + column5period)
Mike, K8LH is offline
Old 26th June 2008, 12:49 PM   #17
Originally Posted by futz View Post
Kewl, huh? And C code is very very portable from PIC to PIC. I wrote code for 16F88 and with only minor changes ran it on 18F248.
Slightly off topic but...
I've been following your progress on the Clock/Calendar/Thermometer project (with Predko 2-pin 74LS174 LCD interface) and I suspected that you didn't have to change much code when porting from the 16F88 to the 18F248. Very nice project and writeup btw (as always)...
Would you consider testing my DayOfWeek routine now that you have calendar capability?
Mike
unsigned char Month = 6;         // 1..12
unsigned char Day = 18;          // 1..31
unsigned char Year = 08;         // 0..99 (2000-2099)
//  71 instructions on 12F683 (BootsC 16)
unsigned char DayOfWeek()        // Mike McLaren, K8LH, Aug '07
{                                // returns 0..6 (Sun..Sat)
  unsigned char Leap = 0;
  const char Base [] = { 5, 1, 1, 4, 6, 2, 4, 0, 3, 5, 1, 3 };
  Leap = (Year & 3) || (Month > 2);
  return (Base[Month-1] + Day + Leap + Year + Year/4) % 7;
Old 26th June 2008, 02:36 PM   #18
Mike,
I can confirm your algorithm works correctly until 1st March 2100.
I wrote a little excel sheet to confirm it.
Pommie is online now
Old 27th June 2008, 04:38 AM   #19
I breadboarded Mike's creation, going by the schematic he provided. Holy hell!!! That's a lot of wires to squeeze onto a little breadboard! As you can see, I gave up keeping it neat after a while. Just too many...
The switches switch GP0 and GP1 between programming mode and run mode.
But it doesn't work!! Some LEDs light, but no action.
Mike! How accurate is that schematic? It doesn't say the resistor values, so I did some educated guessing.
futz is offline
Old 27th June 2008, 04:47 AM   #20
Sorry you're having problems.
Transistors are 2N3904 NPN. Most people see that they're sourcing drivers and assume they're PNP (because the drawing is so fuzzy).
I originally used 510 ohm base resistors and 20 ohm current limiting resistors on the rows but the board in the picture has been taken apart so many times that there are NO resistors at all at the moment. Bad practice I know. It just shows how forgiving this stuff is...
Let me know how it goes?
Mike
Old 27th June 2008, 04:52 AM   #21
I used 2N2222A's with 1.2K base resistors.
I've got 330's on the rows. Too much, but they were there and I wanted to start out safe.
Guess I'll go over the whole thing and trace every wire again. Sigh...
futz is offline
Old 27th June 2008, 05:28 AM   #22
Wrote some test code and I have something happening. LED's are flashing, but not quite properly under my control yet. It's not dead. I just haven't figured out what the problem is yet.
futz is offline
Old 27th June 2008, 05:57 AM   #23
I don't see a bypass cap' across VDD and VSS pins in that photo'.
Old 27th June 2008, 05:59 AM   #24
Nice design Sir ...I like it very much....
May I hack your hardware design? but not the code
Also can you show the underneath of your board Sir if you don't mind?
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline
Old 27th June 2008, 06:07 AM   #25
Nag, nag, nag! OK, OK! I'll put one on there!
I have it working as expected with my code. Wonder if it's my current limiting resistor values that's making yours not appear to work?
futz is offline
Old 27th June 2008, 06:23 AM   #26
A YouTube video of the test code at work.
futz is offline
Old 27th June 2008, 06:33 AM   #27
Futz nice video
I like to compact my real Knight Rider Running Lights project with a compact matrix arrangement on a 8 pin PIC.
I like to do the hardware like Mike did.Anyway I need his rights.
Gayan
My Website
Old 27th June 2008, 01:28 PM   #28
Hi Gayan,
I'm not sure what you mean by "hack my design".
Attached is picture of bottom of board. It contains one surface mount PNP row driver transistor on GP0 (an experiment to increase peak current from 20 ma to around 50 ma).
Mike
BoostC Charlieplexed PWM 32-pwm-20-pcb-bottom.png   BoostC Charlieplexed PWM 32-pwm-20-v2-schem.png
Old 27th June 2008, 01:37 PM   #29
Looks very nice. Did you say my program doesn't work? RGBPhil is using it for his "Cylon Eye"...
Mike
Old 27th June 2008, 01:38 PM   #30
Hi Mike,
Nice demo, what do you have planned for the practical usage of the plex.?
I expect it will be a slighter larger PIC, to enable an external input of some kind.
Regards
ericgibbs is offline
boostc, charlieplexed, pwm
BoostC question.. AddressOf Mike, K8LH Micro Controllers 8 25th June 2008 12:20 AM
LCD degree symbol with sprintf (BoostC) futz Micro Controllers 29 5th June 2008 05:19 AM
math.h and lib for BoostC? futz Micro Controllers 3 31st March 2008 06:29 AM
Charlieplexed code segment for the Cricket Thermostat William At MyBlueRoom Micro Controllers 2 14th March 2006 05:12 PM
My PIC Projects Site NEW (includes 2 Charlieplexed Display) William At MyBlueRoom Electronic Projects Design/Ideas/Reviews 0 28th February 2006 02:31 PM
