Old 22nd June 2008, 12:34 PM   #31
Originally Posted by tunedwolf View Post
Remove U1 and measure again without power being applied, if the measured resistance is still a few ohms, I would agree with you in that you have a short on the board. If the resistance is no longer only a few ohms, measure the pins on U1 for a possible short
I should have been clearer. I tested without U1 and without power.
See the attached pictures (sorry for the very narrow depth of field!). It does seem to me the tracks are joined, I'm unsure if that would cause the problems I'm having.
Junebug VPP problems-junebug-track2.jpg   Junebug VPP problems-junebug-track.jpg
edeca is offline
Old 22nd June 2008, 12:46 PM   #32
Thats a copper track bridge for sure, use a small scalpel blade to cut the bridge.
ericgibbs is offline
Old 22nd June 2008, 12:51 PM   #33
I'm not sure the pictures do it justice, the gap between those tracks is very small and it's wedged between the two sockets! It will be very difficult to cut it without going through one of the tracks
I'll have to work up the courage to play with knives. I actually think there might be another (not quite so bad) on the bottom of the board too.
edeca is offline
Old 22nd June 2008, 02:39 PM   #34
Wow I'll have to check my PCB stock for that bridge, sorry about that I'll have to see what my PCB supplier can do about that. I do leave generous spacing between traces so it must have been something at the PCB shop.
A few cuts with an xacto will fix it, take your time and it should be fine. When I've done it a slow steady cut or two (and a steady hand) will do it. I'm sorry it caused you so much trouble.
Where do you think the other one may be?
Bill
Smart Kits build Smart People
Old 22nd June 2008, 07:47 PM   #35
Under SW5. I've attached a picture, it's cropped so nobody can see more of my awful soldering
I have scraped away the blue covering this time to get a good look.
edeca is offline
Old 23rd June 2008, 09:59 PM   #36
Finally, a post to be happy with.
I made a bit of a mess with the cutting (scored the coating off 1 track) but I got rid of the bridge and didn't cut through either of the proper tracks.
See the photo below, which shows the LED flasher program from the Junebug manual working happily. There appear to be two LEDs on at once due to the slow exposure
However, the photo also shows a missing BS250. I have a replacement here but don't know which lead is which, I'll post a message over in the datasheet request forum if anybody can help. That's the last thing to fix before I start playing with it properly.
Thanks for all the answers, it's great to have it working.
edeca is offline
Old 23rd June 2008, 10:20 PM   #37
Glad to hear you found the problem and got it working, I've been examining the Junebug PCBs for bridges and it seems you've got the only one so far. There is a diode in the BS250 across the drain & source, an ohmmeter will spot it.
The new Junebug manual shows the orientation of both BS250 types.
Bill
Old 23rd June 2008, 10:27 PM   #38
Thanks Bill. If you could confirm that the one I bought is compatible (180mA not 250mA) that would be great, I'll check for the diode.
edeca is offline
Old 23rd June 2008, 11:43 PM   #39
180ma is fine, keep the jumper in place unless you need VDD before VPP programming (only required for some very specialized PIC config modes)
Bill
Old 24th August 2009, 08:50 AM   #40
I seem to be having the same problem as Edeca had. I picked up an assembled Junebug from Creatron last summer (2008). Finally, tried it out recently and when I connect to the PicKit2 software, I get a VPP error. It is the same scenario as Edeca's first post. When I run PICkit2 v2.61 software I immediately get a VPP voltage level error. I can assign an ID to the Junebug, but cannot send a program to it or read what's on the chip. When I run the Troubleshoot option, I'm able to measure proper voltages with a voltmeter. In Troubleshoot Step 2, when I have /MCLR On and then click Test VPP, a short is detected.
Since I purchased it assembled, I'm hesitant to begin desoldering and pulling off components to look for copper cross-overs like Edeca found. There are no visible cross-overs on the bottom of the board at least.
Bill, do you have any particular places you recommend looking for issues?
Thanks, Tom
deputy is offline
Old 24th August 2009, 01:23 PM   #41
A handfull of the first Junebugs built by Creatron had two resistors swapped in the VPP section. Check the PCB silkscreen & partslist against your kit.
The PCB problem is very rare. I'm on my mobile but I'll see if I can give a detailed response this afternoon.
Bill
Old 25th August 2009, 06:17 PM   #42
I see you're in Waterloo deputy, do you get to the GTA often? If so just drop the Junebug off at Creatron and tell Lawrence it's for Bill to fix and I'll drop in and fix it.
Bill
Old 29th August 2009, 08:14 AM   #43
Hi Bill,
I'll be in Toronto for something this weekend.
I'll drop the Junebug off at Creatron Sat morning.
Thanks for the help!
deputy is offline
Old 29th August 2009, 03:18 PM   #44
Ok I'll pick it up and keep you posted on what was wrong with it. I'll get it fixed ASAP.
Bill
Old 8th September 2009, 05:43 PM   #45
Fixed, do you want it mailed via Canada Post or dropped off at Creatron?
Bill
junebug, problems, vpp
Relays on the junebug AtomSoft Micro Controllers 35 3rd April 2008 04:28 AM
Junebug Pics AtomSoft Micro Controllers 15 27th March 2008 08:25 AM
IR with junebug AtomSoft Micro Controllers 5 16th March 2008 03:02 PM
bra & WDT Junebug AtomSoft Micro Controllers 17 3rd March 2008 03:51 PM
My JuneBug is Here! UTMonkey Micro Controllers 15 7th December 2007 07:25 PM
