Hello Eric,
yes, I had the same thought. But I rejected it with reference to the slew rate requirements of the I2C signals. But I didn't check it. Even if my hair ist raising, if it is a serious problem that must be solved, one can use a mini relay to switch. There is no problem with the load or voltage. There are relays which can be controlled directly by the MPU, but one can also use a transistor to drive it. In the net there are a lot of examples available. This solution needs a short delay for debouncing (some ms)between selection of the desired device and the call of the I2C - routine. I hope, this could be a little help for Hesam. With regards Erhard |
hi Erhard,
The analog selectors can be used with Video signals, at +5V, my data shows switching times in the order of a few tens of nanoSecs. Which 'slew rate' are you quoting.?? Look at the HEF series. I know of other users that have connected analog selectors to PIC's/I2C with success.
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
If you do, then simply use another pair of pins to create a second I2C bus, but generally if you've got a clash, it's because you've chosen your devices badly. |
The OP can put a DS1307 (add 0xD0) and a MCP9800 (add 0x90) on the same bus and have no clashes. Should he want to measure 8 different temperatures then he can use the MCP9801 (add 0b1001NNN0) and put 8 of them on the same bus as the 1307 without a clash. You cannot put two DS1307s on the same bus but why would you want two real time clocks in the same system!
If you wanted to measure 16 temperatures and have two real time clocks on your poor little PIC then you can do as Nigel says and implement a software bus. He even has the routines in his tutorial. Mike. |
| 16f877A | watzmann | Micro Controllers | 1 | 9th April 2008 09:41 PM |
| Two VSS & Two VDD in PIC 16F877A. | Suraj143 | Micro Controllers | 15 | 22nd November 2007 08:22 AM |
| RTC with pic 16f877a | fernandoagf | General Electronics Chat | 1 | 14th October 2007 11:12 PM |
| pwm and 16F877A | williB | Micro Controllers | 15 | 12th September 2006 08:08 AM |
| 16F877A help | TKS | Micro Controllers | 9 | 17th March 2004 12:12 PM |
